condor121
Tixati blocks AirVPN connection, reason?
Hi all,
Any reason why whenever I load Tixati, the connection dies immediately. Using Netherlands servers. As soon as I close Tixati, connection comes back. Worked fine 12 hours ago, nothing has changed so much be something server/connection issue. Anyone experiencing similar?
Yes...I have the same problem...just joined AirVPN ...it could be that not many people use Tixati so there is no track record...
I use Tixati on Ubuntu with no issues. Mine pretty much worked out of the box.
I am not a linux guru, so not sure I can help. If you have any questions, or I can provide info to help you find an answer, I wil try my best
All I did to improve speeds, was choose a port number, and forwarded that port. (This was becasue unless you do that you are marked as firewalled on trackers). without port forwarding, it still works, but you can only seed to other non firewalled peers.
I use Tixati on Windows 10 and no issues at all with or without network lock. Have you tried the Torrent address detection on ipleak.net in order to check whether Tixati has connection outside VPN or not?
