icartemo
Eddie Disconnect on Interval
Hello I'm trying to setup the eddie client on windows to automatically disconnect from the server at set intervals and reconnect. The reason for wanting to do this is so that I am connected to the best available server at the time. I would like to set it up so that every 6 hours the client will disconnect from the currently connected server, then right after the disconnect have it reconnect to the best available server. Any help with this would be great.
What if you an operation that you didn't want to be interrupted was in progress at 'automatic disconnect time'? Or, for various reasons, reconnecting may take quite a while and may be will need some manual intervention. It only takes a few seconds to click on the servers tab and connect to something at the top of your whitelist
