Dav23
Huge difference in speed when connected to AirVPN on my PCs
Hoping someone can help me figure out what I am doing wrong here.
Home internet - UPC 240/24 package
PC 1
Gigabit LAN
Windows 8.1
Speedtest when connected to Nunki (Manchester-United Kingdom)
Disconnected from Nunki now, and connecting on PC2
Gigabit LAN
Windows 7 Ultimate
Here is a shot of a speedtest on PC2 when not connected to the VPN
I am using the AirVPN program on Windows to connect and I have the same problem on all servers. PC2 (as well as my laptops) are all under 10Mb/s download when connected to AirVPN. My main PC is the only PC able to get good speeds.
Any ideas guys?
You could try downloading the experimental client in case it's a buffer issue, the current stable client has too low buffers for fast connections which is fixed in the experimental client. This might increase the speed on your primary computer as well. I am using the experimental client myself and it works better than ever. If that doesn't work you could try to downgrading the client to version 2.8 and use the older TAP driver on it. If it doesn't install the old TAP driver automatically try uninstalling the current Eddie client first. The new TAP driver is extremely fast and better than the old one on my Windows 7 64-bit rig but I have seen a few Windows users have (severe) speed issues with it.
Clients are downloaded from the "Enter" tab on this site, by clicking on the Windows icon and then on "other versions".
FromtheWalls,
Thanks for your assistance. I have seen dramatic increases in speed on my second PC and laptops since upgrading to the experimental client.
