Not connected, Your IP: 216.73.216.149
Network lock not working on win XP
Running a virtualmachine (virtualbox) with Windows XP  X32 Pro and installed the newest air client for XP x32.
I "need" the network lock feature to work but i keep getting this error:
"Unable to start Windows Firewall service. Try to switch it from 'Disabled' to 'Manual'."
Anyone know what could cause this?
I tried turning windows firewall on and off and checking "no exceptions", in other words, all the alternatives.
The point of this is to use the VPN for IRC in the VM alone and everything outside the VM- without VPN.
Is it a bug? Can it be fixed?
Any help really apreciated!
EDIT: no additional firewall installed that could interfere with this
Edited ... by ZPKZ
Thanks for the answer. Made me lol
I figured the easiest way to have mirc with the VPN was with a VM. Tried with ubuntu first but mother£$-¤#% wouldn't change screen resolution no matter what so i couldn't see shit, so I tried XP.
I now tried the services.msc and changed to manual. Still wont work
Network Lock is not available for Windows XP. The fact that the option is showed is a bug, fixed in the latest Eddie release for Win XP.
