SonOfC92
Wrong DNS address in network card properties
Hi there,
At one point in time, I had set my primary DNS at 10.4.0.1, and everything worked fine when AirVPN was not in use.
This DNS server does not work any more, so I switched to obtaining DNS automatically.
Whenever I disconnect AirVPN, the primary DNS Address is (re)set to 10.4.0.1.
I have tried to force in the DNS addresses from my ISP, but the problem remains and the address sets again at 10.4.0.1
I have uninstalled and reinstalled AirVPN, to no avail.
Thanks if you can help; it's a bit cumbersome to restore the proper settings in the network card properties whenever AirVPN is disconnected ...
