dc0c06a9
Network Lock questions
No, but if you check the corresponding box in the settings of Eddie (the client) it will be active as soon as you start the client.
In combination to this:
If you set the client to activate network lock and connect to your preferred server on start, while also setting it to start on boot, it achieves what you would like while also instantly tunneling your connection.
If you don't understand anything I say, please ask me.
