Stem
Imminent Withdrawal ?
HI,
Having a problem trying to connect to any server:- Auth Failed.
When checking account, I still have 20 days left. The reason shown in client area for connection failure is "Imminent Withdrawal"
Is there some issue?
Servers marked as closed for "Imminent Withdrawal" are closed to new connections because their withdrawal is imminent. Already connected clients will be disconnected only at the very last minute before the withdrawal. We also recommend that clients connected to such servers disconnect as soon as possible.
Please connect to any open server.
Perhaps in the future, an option could be added to the configuration generator to not include servers that are marked for imminent withdrawal?
This would allow those of us who generate configuration files for the original OpenVPN client to get set up ahead of time.
It seems likely to me that a shift like this may need to be done again some time in the future.
I use the openVPN client for connections, so download config files. There is nothing in the "Config generator" to determine if a sever is closed.
Even though I do get "Auth failed" for the "Closed" servers, the connection shows as active in my "client area".
Is there a list for current servers that I can use?
