diddlysquat 0 Posted ... Recently started AirVPN service and have just configured my Openmediavault server running Deluge to use the service. I have my OMV device connected to a DDWRT configured with AirVPN and are trying to setup Deluge. I have configured the port forward on AirVPN and set the active port on deluge, however when I test the port it returns no result, ie cannot access that port. Any ideas? Quote Share this post Link to post
Staff 10381 Posted ... Hello! Thank you for your subscription. Most probably you need this:https://airvpn.org/topic/9270-how-to-forward-ports-in-dd-wrt-tomato-with-iptables/https://airvpn.org/topic/9270-how-to-forward-ports-in-dd-wrt-tomato-with-iptables Kind regards Quote Share this post Link to post
diddlysquat 0 Posted ... Hi there, Thanks for the response, I have forwarded the ports in DD-WRT using the iptables as listed in that link. Deluge is working albeit with very slow downloads however the 'test active port' function does not return positive result. Any other ideas? Quote Share this post Link to post
