darge_camescope 0 Posted ... My current set up is using the OpenVPN client on Centos7 for Transmission. So whenever the OpenVPN client connects to AirVPN (say after a reboot), I have to manually find the internal IP that's been assigned and tell Transmission to bind to it. Is it possible to have a static internal IP assigned so that I don't have to manually grab the IP? Quote Share this post Link to post
zhang888 1067 Posted ... This will require Air to keep logs inevitably, to assign the connected user the static IP he desired.There are multiple ways to solve it under Linux, the easiest would be switching to a client that isinterface aware, such as the great qBittorrent. The second would be just putting 0.0.0.0 in yourTransmission bind-ipv4 section, to listen on all interfaces: "bind-address-ipv4": "0.0.0.0", Additionally you can set iptables rules to block all traffic to your Torrent port from non tun0 interfaces. Or, you can use the init scripts from here:http://askubuntu.com/questions/583679/transmission-daemon-over-openvpn-on-a-beagleboard-arm-sbcin order to dynamically patch the Transmission file after each reboot. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Tech Jedi Alex 1519 Posted ... Your internal IP is more or less static. It's reserved for you for some time (leased). If you always connect to the same server, you will practically never lose your IP assigned to you. I connect to the german servers and somehow manage to see familiar IPs very often.But I don't know how long this lease time really is. From what I experienced, I think it's seven days. (Sent via Tapatalk - this generally means I'm not sitting in front of my PC) Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
NaDre 161 Posted ... My current set up is using the OpenVPN client on Centos7 for Transmission. So whenever the OpenVPN client connects to AirVPN (say after a reboot), I have to manually find the internal IP that's been assigned and tell Transmission to bind to it. Is it possible to have a static internal IP assigned so that I don't have to manually grab the IP?As giganerd said, so long as you use the same server, this is extremely unlikely to change. But if you do want to change the server often, and you have several daemons that need to be reconfigured, it is indeed a pain. I have for some time been using the technique discussed here: https://airvpn.org/topic/9518-faking-static-local-vpn-addess-using-client-nat-and-ifconfig/?p=10449 But as mentioned at the start of that post, the exact technique there no longer works because AirVPN switched from "net30" to "subnet" topology on March 27, 2015. The basic idea applies though. I made changes to accomodate "subnet" topology. If you want that post updated let me know. I won't provide new scripts though. I will just update the discussion. That post was for Windows rather than Linux. But the same technique will work for Linux, though you need "bash" scripts rather than Windows "batch" scripts. The approach there is still very inconvenient though. When you change servers, you have to first make a connection to the server in order to "auto-update" your OpenVPN configuration files. I have begun using a version of OpenVPN that I patched to add a new configuration command I have tentatively called "ifconfig-nat". It is fairly easy to build OpenVPN from source for Linux yourself (although I have built it for Windows too). So I will paste the patch in at the end of this, in case you want to try it. With the patch applied, I add this line to my configuration files:ifconfig-nat 10.44.0.2 10.44.0.1My local address now appears to be 10.44.0.2. And the remote/gateway address appears to be 10.44.0.1. I have been thinking about posting the patch to the OpenVPN developers forum to solicit comments and see whether this could find its way into the official release. But I may not get to this in a hurry. I will probably put it up on github long before (if ever) it gets into the official release. The thing is though, would there be any point in putting pre-built versions on github? Who would trust them? If however AirVPN decided to host pre-built versions with this patch applied (and maybe push the issue on the OpenVPN forum?), then that might be another matter. ==== The patch is against openvpn-2.3.6. It changes "options.h" and "options.c". The effect is achieved entirely by modifying the configuration, before the OpenVPN connection really gets going (it does need to see the "push" options from the OpenVPN server though). Here is the patch:diff -ur openvpn-2.3.6/src/openvpn/options.c openvpn-2.3.6_patched/src/openvpn/options.c --- openvpn-2.3.6/src/openvpn/options.c 2014-11-29 08:00:35.000000000 -0700 +++ openvpn-2.3.6_patched/src/openvpn/options.c 2015-06-04 14:16:51.511582700 -0600 @@ -192,6 +192,13 @@ " addresses outside of the subnets used by either peer.\n" " TAP: configure device to use IP address l as a local\n" " endpoint and rn as a subnet mask.\n" +#ifdef ENABLE_CLIENT_NAT + "--ifconfig-nat l r [m]: override --ifconfig parameters pushed from server\n" + " and use \"client-nat dnat ...\" and \"client-nat snat ...\"\n" + " commands to map between local and remote addresses.\n" + " use IP address l as local endpoint and r as a remote endpoint.\n" + " optionally use m as netmask for client-nat.\n" +#endif "--ifconfig-ipv6 l r : configure device to use IPv6 address l as local\n" " endpoint (as a /64) and r as remote endpoint\n" "--ifconfig-noexec : Don't actually execute ifconfig/netsh command, instead\n" @@ -3787,6 +3794,98 @@ unsigned int *option_types_found, struct env_set *es); +#ifdef ENABLE_CLIENT_NAT +const char *ifconfig_nat_local = NULL; +const char *ifconfig_nat_remote = NULL; +const char *ifconfig_nat_netmask = NULL; +static void ifconfig_nat_set( + struct options *options, + const int msglevel, + const char *local, + const char *remote, + const char *netmask) { + if (!ifconfig_nat_local || !ifconfig_nat_remote ) { + ifconfig_nat_local = local; + ifconfig_nat_remote = remote; + ifconfig_nat_netmask = netmask; + if (!netmask) + msg (M_INFO, "ifconfig-nat: options set: %s %s", local, remote); + else + msg (M_INFO, "ifconfig-nat: options set: %s %s %s", local, remote, netmask); + } +} +static void ifconfig_nat_apply ( + struct options *options, + const int msglevel) { + if (!(ifconfig_nat_local)) return; + if (!(ifconfig_nat_remote)) return; + if (!(options->ifconfig_local)) return; + if (!(options->ifconfig_remote_netmask)) return; + if (options->topology == TOP_SUBNET) { + if (!(options->route_default_gateway)) return; + cnol_check_alloc (options); + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat snat %s 255.255.255.255 %s\"", + ifconfig_nat_local, options->ifconfig_local); + add_client_nat_to_option_list(options->client_nat, + "snat", ifconfig_nat_local, "255.255.255.255", options->ifconfig_local, msglevel); + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat dnat %s 255.255.255.255 %s\"", + ifconfig_nat_remote, options->route_default_gateway); + add_client_nat_to_option_list(options->client_nat, + "dnat", ifconfig_nat_remote, "255.255.255.255", options->route_default_gateway, msglevel); + if (ifconfig_nat_netmask) { + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat dnat %s %s %s\"", + ifconfig_nat_remote, ifconfig_nat_netmask, options->route_default_gateway); + add_client_nat_to_option_list(options->client_nat, + "dnat", ifconfig_nat_remote, ifconfig_nat_netmask, options->route_default_gateway, + msglevel); + } + else { + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat dnat %s %s %s\"", + ifconfig_nat_remote, options->ifconfig_remote_netmask, options->route_default_gateway); + add_client_nat_to_option_list(options->client_nat, + "dnat", ifconfig_nat_remote, options->ifconfig_remote_netmask, options->route_default_gateway, + msglevel); + } + if (ifconfig_nat_netmask) { + msg (M_INFO, "ifconfig-nat: ifconfig options reset: %s %s", + ifconfig_nat_local, ifconfig_nat_netmask); + options->ifconfig_local = ifconfig_nat_local; + options->ifconfig_remote_netmask = ifconfig_nat_netmask; + } + else { + msg (M_INFO, "ifconfig-nat: ifconfig options reset: %s %s", + ifconfig_nat_local, options->ifconfig_remote_netmask); + options->ifconfig_local = ifconfig_nat_local; + } + msg (M_INFO, "ifconfig-nat: route-gateway option reset: %s", + ifconfig_nat_remote); + options->route_default_gateway = ifconfig_nat_remote; + } + else if (options->topology == TOP_NET30 || options->topology == TOP_P2P) { + cnol_check_alloc (options); + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat snat %s 255.255.255.255 %s\"", + ifconfig_nat_local, options->ifconfig_local); + add_client_nat_to_option_list(options->client_nat, + "snat", ifconfig_nat_local, "255.255.255.255", options->ifconfig_local, msglevel); + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat dnat %s 255.255.255.255 %s\"", + ifconfig_nat_remote, options->ifconfig_remote_netmask); + add_client_nat_to_option_list(options->client_nat, + "dnat", ifconfig_nat_remote, "255.255.255.255", options->ifconfig_remote_netmask, msglevel); + if (ifconfig_nat_netmask) { + msg (M_INFO, "ifconfig-nat: Inserted \"client-nat dnat %s %s %s\"", + ifconfig_nat_remote, ifconfig_nat_netmask, options->ifconfig_remote_netmask); + add_client_nat_to_option_list(options->client_nat, + "dnat", ifconfig_nat_remote, ifconfig_nat_netmask, options->ifconfig_remote_netmask, + msglevel); + } + msg (M_INFO, "ifconfig-nat: ifconfig options reset: %s %s", + ifconfig_nat_local, ifconfig_nat_remote); + options->ifconfig_local = ifconfig_nat_local; + options->ifconfig_remote_netmask = ifconfig_nat_remote; + } +} +#endif + static void read_config_file (struct options *options, const char *file, @@ -3843,6 +3942,9 @@ } CLEAR (line); CLEAR (p); +#ifdef ENABLE_CLIENT_NAT + if (level == 1 && !options->pull) ifconfig_nat_apply(options, msglevel); +#endif } static void @@ -3954,6 +4056,9 @@ add_option (options, p, file, line_num, 0, msglevel, permission_mask, option_types_found, es); } } +#ifdef ENABLE_CLIENT_NAT + ifconfig_nat_apply(options, msglevel); +#endif return true; } @@ -4221,7 +4326,7 @@ port = atoi (p[2]); if (!legal_ipv4_port (port)) { - msg (msglevel, "port number associated with --management directive is out of range"); + msg (msglevel, "port number associated with --management directive is out of range: %s", p[2]); goto err; } } @@ -4412,6 +4517,24 @@ goto err; } } +#ifdef ENABLE_CLIENT_NAT + else if (streq (p[0], "ifconfig-nat") && p[1] && p[2]) { + VERIFY_PERMISSION (OPT_P_GENERAL); + if (!ip_addr_dotted_quad_safe (p[1])) { /* FQDN -- must be IP address */ + msg (msglevel, "ifconfig-nat parameter local '%s' must be an IP address", p[1]); + goto err; + } + if (!ip_addr_dotted_quad_safe (p[2])) { /* FQDN -- must be IP address */ + msg (msglevel, "ifconfig-nat parameter remote '%s' must be an IP address", p[2]); + goto err; + } + if (p[3] && !ip_addr_dotted_quad_safe (p[3])) { /* FQDN -- must be IP address */ + msg (msglevel, "ifconfig-nat parameter netmask '%s' must be an IP address", p[3]); + goto err; + } + ifconfig_nat_set(options, msglevel, p[1], p[2], p[3]); + } +#endif else if (streq (p[0], "ifconfig-ipv6") && p[1] && p[2] ) { unsigned int netbits; Quote Share this post Link to post
rickjames 106 Posted ... One of my OpenBSD rigs has had the same 'internal' ip for a little over 3 weeks while on the same server. No clue how long we keep said ip's. But I ended up writing that ip into the pf.conf as the source. Its still going strong. Quote Share this post Link to post
zombie1982 5 Posted ... Hi, I worked it out by adding a virtual adapter in linux and create a routing table entry for it: Made an if-up.sh script and added it in *ovpn config ifconfig tun0:0 10.0.0.1ipb=10.0.0.1ipx="$(ifconfig tun0|grep "inet "|awk '{ print $2 }'|cut -f1-3 -d.)"sleep 2ip rule add from $ipb table stablevpnip route add default via $ipx.1 table stablevpn Quote Share this post Link to post
