Anonymous_13 33 Posted ... How can I force AirVPN to always connect to the same server even on restart? I connect to a server and click on "lock current" but after a restart the Airvpn client claims about a possible crash and then choose a server with the best latency I believe. Quote Share this post Link to post
Staff 10423 Posted ... Hello! "Lock current" is an option to re-connect to the current server during the current session. For your purpose you need to tick "Force reconnection to last server at startup" in "AirVPN" -> "Preferences". About the alleged crash, please make sure to shut the client down properly. What are your OS and your Eddie version? Kind regards Quote Share this post Link to post
Anonymous_13 33 Posted ... That's already checked. Windows 7 64bit Experimental 2.9AirVPN is shut down by Windows itself when I shut down my computer it ends all running programs. Quote Share this post Link to post
Guest Posted ... That's already checked. Windows 7 64bit Experimental 2.9AirVPN is shut down by Windows itself when I shut down my computer it ends all running programs. you need to manually shut it down else it doesn't save it properly. Quote Share this post Link to post
Anonymous_13 33 Posted ... Did that but after restart the lock current is not ticked again. So in no case it works for me after AirVPN Client is shut down (whether manually or due to windows restart). Quote Share this post Link to post
Guest Posted ... I got it working on mine, I'll give you my settings http://prntscr.com/73hvql http://prntscr.com/73hw2v http://prntscr.com/73hw4r try to perfectly copy all my settings on my 3 screenshots just to test it. Quote Share this post Link to post
