I had this issue as well. You make airVPN make a random port, but you write 32400 in the local port http://prntscr.com/71gxwp and you are good to go =)
BTW you specify on plex the randomized port
I'm gonna assume you got the problem fixed.
Hi
I am using Plex Server with a QNAP NAS, and I hear about this VPN that have port forwarding, so I have issues with the port forwarding with other VPN provider so in this service only need to assign the 32400 port in the VPN console and put the random port in the Plex remote access port?
That screenshoot is from the VPN client or the website? since I running the VPN on a NAS how can setup the port access?
Karl
In Plex set as manual port the same you have mapped in AirVPN
My setup works flawlessly.
Sent from my iPad using Tapatalk
- Router/Firewall pfSense 23.01 (11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz)
- Switch Cisco SG350-10
- AP Netgear RAX200 (Stock FW)
- NAS Synology DS1621+ (5 x 5TB WD Red)
- ISP: Fiber 1000/300 (PPPoE)
