I don't know if this is a problem.
I am in Canada.
I set the vpn IP of my tomato router for Persei in Fremont, California. My AirVPN staus shows that I am indeed connected to Persei.
However, when checking my IP with whatsmyip.org, or checking speed with speedtest.net, it shows the IP address as having been incremented by one, from .162 to .163, and shows that I am connecting from Amsterdam, Holland. What is happening here? Is this a concern? Thanks.
Well Persei is on Swiftway, and they only use RIPE IP's even in the US locations so that's the reason you see NL as the country.
It's quite an issue in case of Maxmind, they don't like to change countries and IPs from different RIRs unless you ask them directly.
94.100.0.0/16 is RIPE Europe, so that's the issue, and in order to get the US flag they need to be from ARIN.
Air promises to deliver the VPN servers -physically- in those countries/cities, and afaik they do their best to keep the geolocation IPs in shape,
but they can't really do nothing with cases like this.
The server is physically in Fremont anyway:
traceroute to persei.airvpn.org (94.100.23.162), 64 hops max, 52 byte packets
 1  10.4.0.1 (10.4.0.1)  97.062 ms  95.114 ms  94.502 ms
 2  * * *
 3  * ae2.mpr1.fra4.de.above.net (94.31.40.213)  111.069 ms  113.873 ms
 4  30gigabitethernet4-3.core1.fra1.he.net (80.81.192.172)  113.996 ms  114.936 ms  111.680 ms
 5  100ge5-2.core1.par2.he.net (72.52.92.13)  128.446 ms  142.723 ms  122.183 ms
 6  10ge15-1.core1.ash1.he.net (184.105.213.93)  259.781 ms  262.394 ms  266.976 ms
 7  10ge9-2.core1.pao1.he.net (184.105.213.177)  332.572 ms  333.419 ms  331.173 ms
 8  10ge4-4.core3.fmt2.he.net (184.105.222.89)  327.741 ms  340.192 ms  333.438 ms
 9  swiftway-2.10gigabitethernet2-3.core1.fmt2.he.net (66.160.172.118)  330.265 ms  329.520 ms  330.735 ms
10  * * *
Why don't you connect to Heze? It's in the same datacenter but with US geolocated IPs, both entry and exit...
