hangpang
Old Client with special compile for Eddie why can't we use it ?
Why can't we use the old client without the special compile for Eddie ?
I was using the old client and then you have disabled it and now I have log in here to get a new client.
Lack of customer service there. Why disable it totally, wouldn't a message be more sensible ?
I don't want to use the Eddie because it has a special compile.
Why are you stopping me from using the open compile ?
Because client series 1 is obsolete and nowadays it poses security concerns. We recommended to stop to use client series 1 almost a year ago.
Yes, you must do that if you wish to use our client. Otherwise you can run any other client, but not our client series 1.
We beg your pardon but it's exactly the opposite. We started to recommend upgrade to client series 2 one year ago. Now a message tells you to upgrade. We repute that one year is enough for everyone.
There is no such thing as a special compile.
It's the opposite, clients series 2 Eddie are FOSS, client series 1 was closed source software. And frankly we don't see your point anywhere for an upgrade that takes 20 seconds and gives you a much more reliable software, not to mention that it's open source software and with tons of additional commodities.
