yko
Cannot connect to airvpn using Tunnelblick on Mac
Hey guys,
I'm new to this airvpn but I'm having a hard time connecting to airvpn.
This info may help: I'm using the UCSF guest wifi since I live in the dorms. I can't even access a cpanel on namecheap.com to write a blog post. This is why I'm trying to set up this VPN.
Posted below is the diagnostic info. Please help. Thanks!
*Tunnelblick: OS X 10.10.2; Tunnelblick 3.5.0 (build 4265); Admin user
Configuration AirVPN_America_UDP-443
"Sanitized" condensed configuration file for /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/AirVPN_America_UDP-443.tblk:
client
dev tun
proto udp
remote america.vpn.airdns.org 443
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
cipher AES-256-CBC
comp-lzo no
verb 3
explicit-exit-notify 5
<ca>
[security-related line(s) omitted]
</ca>
<cert>
</cert>
<key>
</key>
key-direction 1
<tls-auth>
</tls-auth>
"Sanitized" full configuration file
# Air VPN | https://airvpn.org | Tuesday 14th of April 2015 02:28:43 AM
# OpenVPN Client Configuration
# AirVPN_America_UDP-443
client
dev tun
proto udp
nobind
persist-key
persist-tun
cipher AES-256-CBC
comp-lzo no
verb 3
<ca>
</ca>
<cert>
</cert>
<key>
</key>
key-direction 1
<tls-auth>
</tls-auth>
There are no unusual files in AirVPN_America_UDP-443.tblk
Configuration preferences:
-lastConnectionSucceeded = 0
Wildcard preferences:
Program preferences:
launchAtNextLogin = 1
notOKToCheckThatIPAddressDidNotChangeAfterConnection = 0
askedUserIfOKToCheckThatIPAddressDidNotChangeAfterConnection = 1
tunnelblickVersionHistory = (
    "3.5.0 (build 4265)"
lastLaunchTime = 450669149.272603
connectionWindowDisplayCriteria = showWhenConnecting
maxLogDisplaySize = 102400
lastConnectedDisplayName = okyretina
keyboardShortcutIndex = 1
updateCheckAutomatically = 0
updateSendProfileInfo = 0
NSWindow Frame ConnectingWindow = 525 518 389 187 0 0 1440 877
detailsWindowFrameVersion = 4265
detailsWindowFrame = {{262, 308}, {904, 467}}
detailsWindowLeftFrame = {{0, 0}, {162.5, 350}}
leftNavSelectedDisplayName = AirVPN_America_UDP-443
haveDealtWithSparkle1dot5b6 = 1
haveDealtWithOldTunTapPreferences = 1
haveDealtWithOldLoginItem = 1
SUEnableAutomaticChecks = 0
SUScheduledCheckInterval = 86400
SUSendProfileInfo = 0
SULastCheckTime = 2015-04-13 20:47:26 +0000
SUHasLaunchedBefore = 1
WebKitDefaultFontSize = 16
WebKitStandardFont = Times
Tunnelblick Log:
2015-04-13 19:29:02 *Tunnelblick: OS X 10.10.2; Tunnelblick 3.5.0 (build 4265)
2015-04-13 19:29:03 *Tunnelblick: Attempting connection with AirVPN_America_UDP-443 using shadow copy; Set nameserver = 1; monitoring connection
2015-04-13 19:29:03 *Tunnelblick: openvpnstart start AirVPN_America_UDP-443.tblk 1337 1 0 1 0 16688 -ptADGNWradsgnw 2.3.6
2015-04-13 19:29:05 *Tunnelblick: openvpnstart log:
     OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
          /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3.6/openvpn
          --daemon
          --log
          /Library/Application Support/Tunnelblick/Logs/-SUsers-Sokyretina-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN_America_UDP--443.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_16688.1337.openvpn.log
          --cd
          /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk/Contents/Resources
          --config
          /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk/Contents/Resources/config.ovpn
          --cd
          --management
          127.0.0.1
          1337
          --management-query-passwords
          --management-hold
          --script-security
          2
          --up
          /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -d -f -m -w -ptADGNWradsgnw
          --down
          /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -d -f -m -w -ptADGNWradsgnw
2015-04-13 19:29:04 OpenVPN 2.3.6 x86_64-apple-darwin [sSL (OpenSSL)] [LZO] [PKCS11] [MH] [iPv6] built on Apr  3 2015
2015-04-13 19:29:04 library versions: OpenSSL 1.0.1m 19 Mar 2015, LZO 2.08
2015-04-13 19:29:04 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2015-04-13 19:29:04 Need hold release from management interface, waiting...
2015-04-13 19:29:04 *Tunnelblick: openvpnstart starting OpenVPN
2015-04-13 19:29:05 *Tunnelblick: Established communication with OpenVPN
2015-04-13 19:29:05 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2015-04-13 19:29:05 MANAGEMENT: CMD 'pid'
2015-04-13 19:29:05 MANAGEMENT: CMD 'state on'
2015-04-13 19:29:05 MANAGEMENT: CMD 'state'
2015-04-13 19:29:05 MANAGEMENT: CMD 'bytecount 1'
2015-04-13 19:29:05 MANAGEMENT: CMD 'hold release'
2015-04-13 19:29:05 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2015-04-13 19:29:05 Control Channel Authentication: tls-auth using INLINE static key file
2015-04-13 19:29:05 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-04-13 19:29:05 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-04-13 19:29:05 Socket Buffers: R=[196724->65536] S=[9216->65536]
2015-04-13 19:29:05 MANAGEMENT: >STATE:1428978545,RESOLVE,,,
2015-04-13 19:29:05 UDPv4 link local: [undef]
2015-04-13 19:29:05 UDPv4 link remote: [AF_INET]199.19.94.132:443
2015-04-13 19:29:05 MANAGEMENT: >STATE:1428978545,WAIT,,,
ifconfig output:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=3<RXCSUM,TXCSUM>
inet6 ::1 prefixlen 128
inet 127.0.0.1 netmask 0xff000000
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=1<PERFORMNUD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether b8:f6:b1:1a:63:75
inet 10.128.220.59 netmask 0xfffffc00 broadcast 10.128.223.255
inet6 fe80::baf6:b1ff:fe1a:6375%en0 prefixlen 64 scopeid 0x4
media: autoselect
status: active
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=60<TSO4,TSO6>
ether 32:00:13:a7:8c:00
media: autoselect <full-duplex>
status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 32:00:13:a7:8c:01
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 0a:f6:b1:1a:63:75
media: autoselect
status: inactive
awdl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1452
ether 0a:8b:a0:d5:e0:a7
inet6 fe80::88b:a0ff:fed5:e0a7%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
ether ba:f6:b1:a1:43:00
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x2
member: en1 flags=3<LEARNING,DISCOVER>
       ifmaxaddr 0 port 5 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
       ifmaxaddr 0 port 6 priority 0 path cost 0
media: <unknown type>
status: inactive
Console Log:
2015-04-13 14:25:37 tunnelblickd[1546] Status = 0 from tunnelblick-helper command 'connected okyretina.tblk 1'
2015-04-13 16:52:48 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 16:52:48 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 16:52:48 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 16:52:48 tunnelblickd[3162] Status = 0 from tunnelblick-helper command 'kill 1646'
2015-04-13 16:52:49 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 16:52:49 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 16:52:50 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 16:52:50 tunnelblickd[3162] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 18:43:42 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:43:42 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:43:42 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:43:42 tunnelblickd[3311] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 18:43:43 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:43:43 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:43:43 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:43:43 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 18:43:44 tunnelblickd[3311] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1337 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 18:44:26 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:44:26 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:44:26 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:44:26 tunnelblickd[3330] Status = 0 from tunnelblick-helper command 'kill 3316'
2015-04-13 18:44:27 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:44:27 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:44:27 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:44:27 tunnelblickd[3330] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 18:50:23 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:50:23 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:50:23 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:50:23 tunnelblickd[3513] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 18:50:24 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:50:24 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:50:24 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:50:24 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 18:50:25 tunnelblickd[3513] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1337 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 18:51:28 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:51:28 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:51:28 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:51:29 tunnelblickd[3533] Status = 0 from tunnelblick-helper command 'kill 3518'
2015-04-13 18:51:29 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:51:30 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:51:30 Tunnelblick[718] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:51:30 tunnelblickd[3533] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 18:51:52 Tunnelblick[718] setShutdownVariables: invoked, but have already set them
2015-04-13 18:51:52 Tunnelblick[718] applicationShouldTerminate: termination because of restart; delayed until 'shutdownTunnelblick' finishes
2015-04-13 18:51:52 Tunnelblick[718] Finished shutting down Tunnelblick; allowing termination
2015-04-13 18:52:29 Tunnelblick[304] Set program update feedURL to https://www.tunnelblick.net/appcast-s.rss
2015-04-13 18:52:56 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:52:56 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:52:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:52:57 tunnelblickd[529] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 18:52:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:52:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:52:57 tunnelblickd[529] Status = 0 from tunnelblick-helper command 'printSanitizedConfigurationFile okyretina.tblk 0'
2015-04-13 18:52:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:52:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:52:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:52:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 18:52:59 tunnelblickd[529] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1337 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 18:55:01 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:01 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:01 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:01 tunnelblickd[631] Status = 0 from tunnelblick-helper command 'kill 536'
2015-04-13 18:55:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:03 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:03 tunnelblickd[631] Status = 0 from tunnelblick-helper command 'unloadKexts 1'
2015-04-13 18:55:03 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:03 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:03 tunnelblickd[631] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 18:55:05 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:06 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:06 tunnelblickd[631] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 18:55:06 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:06 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:06 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 18:55:07 tunnelblickd[631] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1338 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 18:55:48 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:48 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:49 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:49 tunnelblickd[648] Status = 0 from tunnelblick-helper command 'kill 642'
2015-04-13 18:55:50 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:50 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:50 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:50 tunnelblickd[648] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 18:55:53 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:53 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:53 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:53 tunnelblickd[648] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 18:55:54 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 18:55:54 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 18:55:54 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 18:55:54 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 18:55:55 tunnelblickd[648] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1337 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 19:07:01 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:07:01 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:07:01 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:07:01 tunnelblickd[752] Status = 0 from tunnelblick-helper command 'kill 657'
2015-04-13 19:07:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:07:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:07:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:07:02 tunnelblickd[752] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 19:07:14 Tunnelblick[304] Beginning installation or repair
2015-04-13 19:07:14 authexec[760] executing /Applications/Tunnelblick.app/Contents/Resources/installer
2015-04-13 19:07:15 Tunnelblick[304] Installation or repair succeeded; Log:
                                       Tunnelblick installer started 2015-04-13 19:07:14. 2 arguments: 0x2001
                                            /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk
                                       removed /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk
                                       removed /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk
                                       Tunnelblick installer finished without error
2015-04-13 19:07:15 Tunnelblick[304] Uninstalled configuration file /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk
2015-04-13 19:07:25 Tunnelblick[304] Converting/Installing /Users/okyretina/Documents/openvpn/okyretina.ovpn: Converted OpenVPN configuration
2015-04-13 19:07:31 Tunnelblick[304] Beginning installation or repair
2015-04-13 19:07:31 authexec[778] executing /Applications/Tunnelblick.app/Contents/Resources/installer
2015-04-13 19:07:31 Tunnelblick[304] Installation or repair succeeded; Log:
                                       Tunnelblick installer started 2015-04-13 19:07:31. 3 arguments: 0x0001
                                            /private/var/folders/kt/b_hmb5r51q12p3y0f_s3z3rh0000gn/T/Tunnelblick-yxi4iX/okyretina.tblk
                                       Copied /private/var/folders/kt/b_hmb5r51q12p3y0f_s3z3rh0000gn/T/Tunnelblick-yxi4iX/okyretina.tblk
                                           to /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk.temp
                                       Renamed /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk.temp
                                       Changed ownership of /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk and its contents from 501:20 to 501:80
                                       Copied /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk
                                           to /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk.temp
                                       Renamed /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk.temp
                                       Changed ownership of /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk and its contents from 501:80 to 0:0
                                       Changed permissions from 750 to 755 on /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk
                                       Changed permissions from 750 to 755 on /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk/Contents
                                       Changed permissions from 750 to 755 on /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk/Contents/Resources
                                       Changed permissions from 740 to 700 on /Library/Application Support/Tunnelblick/Users/okyretina/okyretina.tblk/Contents/Resources/config.ovpn
                                       Created secure (shadow) copy of okyretina.tblk
2015-04-13 19:07:41 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:07:41 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:07:41 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:07:41 tunnelblickd[781] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 19:07:42 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:07:42 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:07:42 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:07:42 tunnelblickd[781] Status = 0 from tunnelblick-helper command 'printSanitizedConfigurationFile okyretina.tblk 0'
2015-04-13 19:07:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:07:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:07:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:07:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 19:07:58 tunnelblickd[781] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1337 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 19:18:50 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:18:50 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:18:51 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:18:51 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'kill 788'
2015-04-13 19:18:52 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:18:52 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:18:52 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:18:52 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 19:18:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:18:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:18:57 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:18:57 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 19:18:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:18:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:18:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:18:58 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 19:18:59 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1338 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 19:19:05 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:19:05 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:19:05 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:19:05 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'kill 848'
2015-04-13 19:19:06 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:19:06 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:19:07 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:19:07 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 19:19:11 Tunnelblick[304] Beginning installation or repair
2015-04-13 19:19:11 authexec[856] executing /Applications/Tunnelblick.app/Contents/Resources/installer
2015-04-13 19:19:12 Tunnelblick[304] Installation or repair succeeded; Log:
                                       Tunnelblick installer started 2015-04-13 19:19:11. 2 arguments: 0x2001
2015-04-13 19:19:12 Tunnelblick[304] Uninstalled configuration file /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/okyretina.tblk
2015-04-13 19:19:20 Tunnelblick[304] Converting/Installing /Users/okyretina/Documents/openvpn/okyretina.ovpn: Converted OpenVPN configuration
2015-04-13 19:19:25 Tunnelblick[304] Beginning installation or repair
2015-04-13 19:19:25 authexec[866] executing /Applications/Tunnelblick.app/Contents/Resources/installer
2015-04-13 19:19:25 Tunnelblick[304] Installation or repair succeeded; Log:
                                       Tunnelblick installer started 2015-04-13 19:19:25. 3 arguments: 0x0001
                                            /private/var/folders/kt/b_hmb5r51q12p3y0f_s3z3rh0000gn/T/Tunnelblick-UELbW8/okyretina.tblk
                                       Copied /private/var/folders/kt/b_hmb5r51q12p3y0f_s3z3rh0000gn/T/Tunnelblick-UELbW8/okyretina.tblk
2015-04-13 19:19:29 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:19:29 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:19:29 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:19:29 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'compareShadowCopy okyretina'
2015-04-13 19:19:30 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:19:30 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:19:30 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:19:30 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'printSanitizedConfigurationFile okyretina.tblk 0'
2015-04-13 19:19:33 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:19:33 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:19:33 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:19:33 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 19:19:34 tunnelblickd[840] Status = 0 from tunnelblick-helper command 'start okyretina.tblk 1337 3 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 19:21:28 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:21:28 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:21:28 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:21:28 tunnelblickd[883] Status = 0 from tunnelblick-helper command 'kill 874'
2015-04-13 19:21:29 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:21:29 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:21:29 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:21:29 tunnelblickd[883] Status = 0 from tunnelblick-helper command 'postDisconnect okyretina.tblk 1'
2015-04-13 19:28:51 Tunnelblick[304] Converting/Installing /Users/okyretina/Downloads/AirVPN_America_UDP-443.ovpn: Converted OpenVPN configuration
2015-04-13 19:28:56 Tunnelblick[304] Beginning installation or repair
2015-04-13 19:28:56 authexec[958] executing /Applications/Tunnelblick.app/Contents/Resources/installer
2015-04-13 19:28:57 Tunnelblick[304] Installation or repair succeeded; Log:
                                       Tunnelblick installer started 2015-04-13 19:28:56. 3 arguments: 0x0001
                                            /private/var/folders/kt/b_hmb5r51q12p3y0f_s3z3rh0000gn/T/Tunnelblick-F2POkT/AirVPN_America_UDP-443.tblk
                                       Copied /private/var/folders/kt/b_hmb5r51q12p3y0f_s3z3rh0000gn/T/Tunnelblick-F2POkT/AirVPN_America_UDP-443.tblk
                                           to /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/AirVPN_America_UDP-443.tblk.temp
                                       Renamed /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/AirVPN_America_UDP-443.tblk.temp
                                       Changed ownership of /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/AirVPN_America_UDP-443.tblk and its contents from 501:20 to 501:80
                                       Copied /Users/okyretina/Library/Application Support/Tunnelblick/Configurations/AirVPN_America_UDP-443.tblk
                                           to /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk.temp
                                       Renamed /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk.temp
                                       Changed ownership of /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk and its contents from 501:80 to 0:0
                                       Changed permissions from 750 to 755 on /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk
                                       Changed permissions from 750 to 755 on /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk/Contents
                                       Changed permissions from 750 to 755 on /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk/Contents/Resources
                                       Changed permissions from 740 to 700 on /Library/Application Support/Tunnelblick/Users/okyretina/AirVPN_America_UDP-443.tblk/Contents/Resources/config.ovpn
                                       Created secure (shadow) copy of AirVPN_America_UDP-443.tblk
2015-04-13 19:29:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:29:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:29:02 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:29:02 tunnelblickd[960] Status = 0 from tunnelblick-helper command 'compareShadowCopy AirVPN_America_UDP-443'
2015-04-13 19:29:03 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:29:03 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:29:03 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:29:03 tunnelblickd[960] Status = 0 from tunnelblick-helper command 'printSanitizedConfigurationFile AirVPN_America_UDP-443.tblk 0'
2015-04-13 19:29:04 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:29:04 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:29:04 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.800000 seconds...
2015-04-13 19:29:04 tunnelblickd[960] Status = 0 from tunnelblick-helper command 'start AirVPN_America_UDP-443.tblk 1337 1 0 1 0 16688 -ptADGNWradsgnw 2.3.6'
2015-04-13 19:29:52 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.100000 seconds...
2015-04-13 19:29:53 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.200000 seconds...
2015-04-13 19:29:53 Tunnelblick[304] runTunnelblickd: no data available from tunnelblickd socket; sleeping 0.400000 seconds...
2015-04-13 19:29:53 tunnelblickd[972] Status = 0 from tunnelblick-helper command 'printSanitizedConfigurationFile AirVPN_America_UDP-443.tblk 0'
Non-Apple kexts that are loaded:
Index Refs Address            Size       Wired      Name (Version) <Linked Against>
  132    0 0xffffff7f82fa9000 0x14000    0x14000    com.intel.kext.intelhaxm (1.1.1) <7 5 4 3 1>
Why not use AirVPN's own client? It works very well on OSX Mavericks and Yosemite. Just a thought.
I suggest use Viscosity as VPN Client, I have a lot of problems with Tunnelblick.
Viscosity can import Tunnelblick OVPN files with double click on them. Why not use AirVPN client because is not the only VPN service that you want use.
http://www.sparklabs.com/viscosity/
