Miguel Antunes
Clients connect to secound Router
My configuration:
Router 1
ISP Fritzbox 7290
IP: 192.168.0.1
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
And i have a secound router with DDWRT, with this configuration and with the AIRVPN
Route2
DDWRT ROuter
Wan IP: 192.168.0.2
IP: 192.168.1.1
Gateway: 192.168.1.1
All my pcs connected to the Router 1 cant connect to the PCs in Router 2, an example i cant connec to the Web GUI 192.168.1.1 if i am connected in the router 1.
There is a way to fix this?
I dont have any firewall rule active, and the firewall is disabled.
The AirVPN works OK all my PCs in Router2 are under the VPN, but i can connect under the router 1 to one ftp server in router 2, or ping any pc in the router 2.
It seems a networking issue that doesn't have a direct relation with airVPN so thats why you are not getting any answer
 What mode is set Router 2: access point, client, bridged client, routed or repeater? Is router2 connected wirelessly to router1? You can found the differences here http://www.dd-wrt.com/wiki/index.php/Linking_Routers
