timde9 3 Posted ... I am having kinda an annoying issue with my asus ac66u router. I want to setup AirVPN on the router via openvpn which is supported through the stock firmware. I tried dd-wrt but the latest builds don't detect my 5ghz radio correctly so that's a no go. Anyway the stupid router configuration has a line limit on how long the user key can be and I am over by a few lines. Is there any way in the config generator to generate a smaller user.key file or am I just out of luck on this? Quote Share this post Link to post
InactiveUser 188 Posted ... I don't think you can make the key any smaller, but you could try the Tomato firmware. According to these instructions, it detects the 5GHz band after resetting NVRAM and rebooting twice. Numerous posts in this thread also suggest changing the country code in order to get 80MHz channels @ 5GHz. 2 rickjames and vpnair33 reacted to this Quote Hide InactiveUser's signature Hide all signatures all of my content is released under CC-BY-SA 2.0 Share this post Link to post
go558a83nk 383 Posted ... for an asus router merlin asus firmware is the way to go http://asuswrt.lostrealm.ca/ Quote Share this post Link to post
timde9 3 Posted ... Hey guys I got dd-wrt to work I just had to try several builds before one worked. Thanks a ton for the help :] Quote Share this post Link to post
knighthawk 19 Posted ... +1 on the recommendation for Merlin's builds (or John's fork of same). Quote Share this post Link to post
vud2001 0 Posted ... I have this same issue with the openvpn client on my Asus RT-AC52U. Has anyone sucessfully used the Asus openvpn client to connect to AirVPN? Unfortunately it looks like there isn't an alternative firmware for this router. Quote Share this post Link to post
