edobrez
Exception starting airvpn on RHEL 6.6
launching the portable client on RHEL 6.6 I get this exception,
however the .so file is present in the same directory as the airvpn executable
any ideas ?
I tested that airvpn works on a Centos 7 system that has no mono packages installed
[ airvpn_linux_x64_portable]$ ls
airvpn  libgdiplus.so.0  libMonoPosixHelper.so  openvpn  stunnel  update-resolv-conf
[ airvpn_linux_x64_portable]$ sudo ./airvpn
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Native.Syscall ---> System.DllNotFoundException: ./libMonoPosixHelper.so
  at (wrapper managed-to-native) Mono.Unix.Native.Syscall:_L_ctermid ()
  at Mono.Unix.Native.Syscall..cctor () [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at AirVPN.Platforms.Linux.GetExecutablePath () [0x00000] in <filename unknown>:0
  at AirVPN.Core.Platform.GetProgramFolder () [0x00000] in <filename unknown>:0
  at AirVPN.Core.Engine.Initialization () [0x00000] in <filename unknown>:0
  at AirVPN.UI.Linux.Program.Main () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Native.Syscall ---> System.DllNotFoundException: ./libMonoPosixHelper.so
I get the same error for the portable version on CentOS 6.6. The good news: the rpm version works and pulls in all dependencies (EPEL repos have to be enabled!).
After installing the rpm, I tried the portable version again to see a different error message:
symbol lookup error: ./libgdiplus.so.0: undefined symbol: g_mutex_lock
Bummer, but at least the rpm version works.
I don't know whether you already tried the rpm (or whether that's an option for you) but if it works on CentOS 6.6 it should also work on RHEL.
Thanks,
I could verify it works although I'd rather have avoided pulling in packages and would have preferred the stanadalone version
(which worked flawlessly on centos7).
cheers
