URL260 3 Posted ... Hello,is it possible to have routing to Switzerland? There's only one server available for this country and i can't use two devices simultaneously to stream Swiss TV. Thank you in advance Quote Share this post Link to post
Staff 10299 Posted ... Hello! We will consider this option in the near future. In the meantime, you could connect both devices to the same server, provided that you don't need remote port forwarding. Just connect the devices to different ports to prevent conflicts. For example, device 1 to port 443 (UDP) and device 2 to port 80 (UDP). Kind regards 1 URL260 reacted to this Quote Share this post Link to post
URL260 3 Posted ... Hello! We will consider this option in the near future. In the meantime, you could connect both devices to the same server, provided that you don't need remote port forwarding. Just connect the devices to different ports to prevent conflicts. For example, device 1 to port 443 (UDP) and device 2 to port 80 (UDP). Kind regardsI'll try connecting using different ports.Thank you! Quote Share this post Link to post
