Not connected, Your IP: 216.73.216.161
Pack 1
. 2015.02.24 12:19:18 - Updating systems & servers data ...
I 2015.02.24 12:19:19 - OpenVPN Driver - TAP-Windows Adapter V9
I 2015.02.24 12:19:19 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVP
N\openvpn.exe)
I 2015.02.24 12:19:19 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink
.exe)
I 2015.02.24 12:19:19 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stu
nnel.exe)
I 2015.02.24 12:19:19 - IPV6: Available
I 2015.02.24 12:19:19 - Checking login ...
. 2015.02.24 12:19:19 - Checking login ..., 1° try failed (Length of the data to
 decrypt is invalid.)
. 2015.02.24 12:19:19 - Updating systems & servers data ..., 1° try failed (Leng
th of the data to decrypt is invalid.)
. 2015.02.24 12:19:20 - Checking login ..., 2° try failed (Length of the data to
. 2015.02.24 12:19:20 - Updating systems & servers data ..., 2° try failed (Leng
. 2015.02.24 12:19:20 - Checking login ..., 3° try failed (Length of the data to
. 2015.02.24 12:19:20 - Updating systems & servers data ..., 3° try failed (Leng
. 2015.02.24 12:19:20 - Checking login ..., 4° try failed (Length of the data to
. 2015.02.24 12:19:20 - Updating systems & servers data ..., 4° try failed (Leng
. 2015.02.24 12:19:20 - Checking login ..., 5° try failed (Length of the data to
. 2015.02.24 12:19:21 - Updating systems & servers data ..., 5° try failed (Leng
. 2015.02.24 12:19:21 - Checking login ..., 6° try failed (Length of the data to
. 2015.02.24 12:19:21 - Updating systems & servers data ..., 6° try failed (Leng
. 2015.02.24 12:19:21 - Checking login ..., 7° try failed (Length of the data to
. 2015.02.24 12:19:21 - Updating systems & servers data ..., 7° try failed (Leng
. 2015.02.24 12:19:21 - Checking login ..., 8° try failed (Length of the data to
F 2015.02.24 12:19:21 - Cannot login. (Length of the data to decrypt is invalid.
! 2015.02.24 12:19:21 - Ready
. 2015.02.24 12:19:21 - Updating systems & servers data ..., 8° try failed (Leng
W 2015.02.24 12:19:21 - Cannot retrieve systems & servers data. Please retry lat
er or contact us for help. (Length of the data to decrypt is invalid.)
You should show us your logs . Either try shortening your password or try the Beta client (which I see you're looking at now). If you're using a client older than 2.10, you could also simply update to 2.10.
