OldThor
ANSWERED AirVPN stopped working on 1 of my 2 PCs
I'm a fairly new user of AirVPN, which is my first VPN ever.
I use it on 2 PCs, both under Windows 7 64-bit, via OpenVPN.
At first it worked fine on both PCs, http://www.whatismyip.com/ showed the IP AirVPN provided. A couple of days ago I noted that on one of those PCs, a laptop, http://www.whatismyip.com/ shows my actual IP, though AirVPN reports to be connected. Looking at the status, there are some error messages:
Thu Feb 19 12:28:16 2015 OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [iPv6] built on Dec  1 2014
Thu Feb 19 12:28:16 2015 library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.08
Thu Feb 19 12:28:16 2015 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Thu Feb 19 12:28:16 2015 Need hold release from management interface, waiting...
Thu Feb 19 12:28:16 2015 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Thu Feb 19 12:28:16 2015 MANAGEMENT: CMD 'state on'
Thu Feb 19 12:28:16 2015 MANAGEMENT: CMD 'log all on'
Thu Feb 19 12:28:16 2015 MANAGEMENT: CMD 'hold off'
Thu Feb 19 12:28:16 2015 MANAGEMENT: CMD 'hold release'
Thu Feb 19 12:28:16 2015 Control Channel Authentication: tls-auth using INLINE static key file
Thu Feb 19 12:28:16 2015 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb 19 12:28:16 2015 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb 19 12:28:16 2015 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Feb 19 12:28:16 2015 MANAGEMENT: >STATE:1424341696,RESOLVE,,,
Thu Feb 19 12:28:17 2015 UDPv4 link local: [undef]
Thu Feb 19 12:28:17 2015 UDPv4 link remote: [AF_INET]37.48.81.7:443
Thu Feb 19 12:28:17 2015 MANAGEMENT: >STATE:1424341697,WAIT,,,
Thu Feb 19 12:28:17 2015 MANAGEMENT: >STATE:1424341697,AUTH,,,
Thu Feb 19 12:28:17 2015 TLS: Initial packet from [AF_INET]37.48.81.7:443, sid=d82f4550 f8d7b69b
Thu Feb 19 12:28:18 2015 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Thu Feb 19 12:28:18 2015 Validating certificate key usage
Thu Feb 19 12:28:18 2015 ++ Certificate has key usage  00a0, expects 00a0
Thu Feb 19 12:28:18 2015 VERIFY KU OK
Thu Feb 19 12:28:18 2015 Validating certificate extended key usage
Thu Feb 19 12:28:18 2015 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Feb 19 12:28:18 2015 VERIFY EKU OK
Thu Feb 19 12:28:18 2015 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Thu Feb 19 12:28:25 2015 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Feb 19 12:28:25 2015 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb 19 12:28:25 2015 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Feb 19 12:28:25 2015 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb 19 12:28:25 2015 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Thu Feb 19 12:28:25 2015 [server] Peer Connection Initiated with [AF_INET]37.48.81.7:443
Thu Feb 19 12:28:26 2015 MANAGEMENT: >STATE:1424341706,GET_CONFIG,,,
Thu Feb 19 12:28:27 2015 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Feb 19 12:28:27 2015 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.148.170 10.4.148.169'
Thu Feb 19 12:28:27 2015 OPTIONS IMPORT: timers and/or timeouts modified
Thu Feb 19 12:28:27 2015 OPTIONS IMPORT: LZO parms modified
Thu Feb 19 12:28:27 2015 OPTIONS IMPORT: --ifconfig/up options modified
Thu Feb 19 12:28:27 2015 OPTIONS IMPORT: route options modified
Thu Feb 19 12:28:27 2015 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Feb 19 12:28:27 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Feb 19 12:28:27 2015 MANAGEMENT: >STATE:1424341707,ASSIGN_IP,,10.4.148.170,
Thu Feb 19 12:28:27 2015 open_tun, tt->ipv6=0
Thu Feb 19 12:28:27 2015 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{FF5C61E2-72C9-4519-8A43-A588929DB61B}.tap
Thu Feb 19 12:28:27 2015 TAP-Windows Driver Version 9.9
Thu Feb 19 12:28:27 2015 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.148.170/255.255.255.252 on interface {FF5C61E2-72C9-4519-8A43-A588929DB61B} [DHCP-serv: 10.4.148.169, lease-time: 31536000]
Thu Feb 19 12:28:27 2015 NOTE: FlushIpNetTable failed on interface [18] {FF5C61E2-72C9-4519-8A43-A588929DB61B} (status=5) : Access is denied
Thu Feb 19 12:28:32 2015 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Thu Feb 19 12:28:32 2015 C:\Windows\system32\route.exe ADD 37.48.81.7 MASK 255.255.255.255 10.100.102.1
Thu Feb 19 12:28:32 2015 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied.   [status=5 if_index=11]
Thu Feb 19 12:28:32 2015 Route addition via IPAPI failed [adaptive]
Thu Feb 19 12:28:32 2015 Route addition fallback to route.exe
Thu Feb 19 12:28:32 2015 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Thu Feb 19 12:28:32 2015 ERROR: Windows route add command failed [adaptive]: returned error code 1
Thu Feb 19 12:28:32 2015 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.148.169
Thu Feb 19 12:28:32 2015 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied.   [status=5 if_index=18]
Thu Feb 19 12:28:32 2015 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.148.169
Thu Feb 19 12:28:32 2015 MANAGEMENT: >STATE:1424341712,ADD_ROUTES,,,
Thu Feb 19 12:28:32 2015 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.148.169
Thu Feb 19 12:28:32 2015 Initialization Sequence Completed
Thu Feb 19 12:28:32 2015 MANAGEMENT: >STATE:1424341712,CONNECTED,SUCCESS,10.4.148.170,37.48.81.7
What can I do?
Please make sure to run OpenVPN or OpenVPN GUI with adminstrator privileges. You might also like to use our free and open source client Eddie.
Thank you.
Starting OpenVPN GUI as administrator solved it.
BTW, I didn't see you client on the website here.
