zsam288
Unhandled exception
I get the below error when starting the AirVPN clien (v2.8 but older versions have the same error)
when i press continue, the client works as expected
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at AirVPN.Gui.Forms.Main.EnabledUi()
   at AirVPN.Gui.Forms.Main.OnResize(EventArgs e)
   at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   at System.Windows.Forms.Control.UpdateBounds()
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UI.Windows
    Assembly Version: 2.8.0.0
    Win32 Version: 2.8.0.0
    CodeBase: file:///C:/Program%20Files/AirVPN/AirVPN.exe
Lib.Core
    CodeBase: file:///C:/Program%20Files/AirVPN/Lib.Core.DLL
Lib.Forms
    CodeBase: file:///C:/Program%20Files/AirVPN/Lib.Forms.DLL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Platforms.Windows
    CodeBase: file:///C:/Program%20Files/AirVPN/Platforms.Windows.DLL
System.Xml
    Win32 Version: 4.0.30319.34230 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
UI.Windows
Lib.Core
Lib.Forms
System.Drawing
System
Platforms.Windows
System.Xml
enabled.
For example:
<configuration>
</configuration>
