i3luefire
Connection trouble at school
When I use openVPN on android to connect to AirVPN servers with tcp on port 80.
  1. it connects
  2. Airvpn.org shows my ip address is an AirVPN address
  3. seems to work fine
When I use the AirVPN client on windows 8.1
  1. it continuously tries to connect
  2. it fails to connect
  3. logs http://pastebin.com/RsiFcePe
  4. i have tried all the ports
  5. i have tried ssh tunnel
  6. i have tried ssl tunnel
When I use the OpenVPN GUI application on windows 8.1 on port 80 with tcp
  1. it connects but
  2. my ip still shows the school ip
  3. logs http://pastebin.com/VA9saF8c
all the methods of connecting work from my home and from my job.
the first paste has been removed. About the second one, a problem is showed in this line:
Mon Jan 26 09:42:55 2015 NOTE: FlushIpNetTable failed on interface [40] {C8CDFB48-32F6-4E17-9DFD-6E2BDAB09FEE} (status=5) : Access is denied.
Make sure to run OpenVPN GUI with Administrator privileges.
