abcd123
Problem : Constant connect. then disconnect and then reconnect
I am having constant connect, then disconnect then reconnect.
it never connects actually
everything was working fine until i upgraded Eddie from 2.4 to 2.8
even for some hours everthing was working fine on eddie 2.8
then suddenly it started
here are the logs
I 2015.01.20 11:29:01 - Session starting.
I 2015.01.20 11:29:01 - Installing tunnel driver
I 2015.01.20 11:29:01 - Checking authorization ...
! 2015.01.20 11:29:02 - Connecting to Acrux (Netherlands, Amsterdam)
. 2015.01.20 11:29:02 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.01.20 11:29:02 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.01.20 11:29:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.01.20 11:29:02 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.01.20 11:29:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.20 11:29:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.20 11:29:02 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.01.20 11:29:02 - OpenVPN > UDPv4 link local: [undef]
. 2015.01.20 11:29:02 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.12:443
. 2015.01.20 11:29:34 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.01.20 11:29:34 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.01.20 11:29:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.01.20 11:29:39 - Disconnecting
. 2015.01.20 11:29:39 - Connection terminated.
I 2015.01.20 11:29:42 - Checking authorization ...
! 2015.01.20 11:29:43 - Connecting to Syrma (Netherlands, Amsterdam)
. 2015.01.20 11:29:43 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.01.20 11:29:43 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.01.20 11:29:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.01.20 11:29:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.01.20 11:29:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.20 11:29:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.20 11:29:43 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.01.20 11:29:43 - OpenVPN > UDPv4 link local: [undef]
. 2015.01.20 11:29:43 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.7:443
. 2015.01.20 11:29:43 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.81.7:443, sid=2898d4f9 7fd941bb
. 2015.01.20 11:29:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.01.20 11:29:45 - OpenVPN > Validating certificate key usage
. 2015.01.20 11:29:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.01.20 11:29:45 - OpenVPN > VERIFY KU OK
. 2015.01.20 11:29:45 - OpenVPN > Validating certificate extended key usage
. 2015.01.20 11:29:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.01.20 11:29:45 - OpenVPN > VERIFY EKU OK
. 2015.01.20 11:29:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.01.20 11:29:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.01.20 11:29:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.20 11:29:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.01.20 11:29:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.20 11:29:48 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.01.20 11:29:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.81.7:443
. 2015.01.20 11:29:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.01.20 11:29:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.42.18 10.4.42.17'
. 2015.01.20 11:29:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.01.20 11:29:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.01.20 11:29:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.01.20 11:29:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.01.20 11:29:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.01.20 11:29:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.01.20 11:29:50 - OpenVPN > open_tun, tt->ipv6=0
. 2015.01.20 11:29:51 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{370440A4-4891-40EA-9C1C-37BD0245A004}.tap
. 2015.01.20 11:29:51 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.01.20 11:29:51 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.42.18/255.255.255.252 on interface {370440A4-4891-40EA-9C1C-37BD0245A004} [DHCP-serv: 10.4.42.17, lease-time: 31536000]
. 2015.01.20 11:29:51 - OpenVPN > Successful ARP Flush on interface [27] {370440A4-4891-40EA-9C1C-37BD0245A004}
. 2015.01.20 11:29:56 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.01.20 11:29:56 - OpenVPN > C:\Windows\system32\route.exe ADD 37.48.81.7 MASK 255.255.255.255 192.168.1.1
. 2015.01.20 11:29:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2015.01.20 11:29:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.01.20 11:29:56 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.42.17
. 2015.01.20 11:29:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.01.20 11:29:56 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.42.17
. 2015.01.20 11:29:56 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.42.17
. 2015.01.20 11:29:56 - Starting Management Interface
. 2015.01.20 11:29:56 - OpenVPN > Initialization Sequence Completed
I 2015.01.20 11:29:56 - Flushing DNS
I 2015.01.20 11:29:56 - Checking route
I 2015.01.20 11:29:58 - Checking DNS
E 2015.01.20 11:29:58 - DNS checking failed.
. 2015.01.20 11:29:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.01.20 11:29:58 - Disconnecting
. 2015.01.20 11:29:58 - Management - Send 'signal SIGTERM'
. 2015.01.20 11:29:58 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.01.20 11:29:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.01.20 11:29:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.01.20 11:30:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.42.17
. 2015.01.20 11:30:03 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.01.20 11:30:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 37.48.81.7 MASK 255.255.255.255 192.168.1.1
. 2015.01.20 11:30:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.42.17
. 2015.01.20 11:30:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.42.17
. 2015.01.20 11:30:03 - OpenVPN > Closing TUN/TAP interface
. 2015.01.20 11:30:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.01.20 11:30:03 - Connection terminated.
I 2015.01.20 11:30:04 - Cancel requested.
! 2015.01.20 11:30:11 - Session terminated.
. 2015.01.20 11:37:09 - Updating systems & servers data ...
. 2015.01.20 11:37:11 - Systems & servers data update completed
