legendofrick100
Can't connect to VPN. DNS problem
I 2015.01.03 07:58:38 - Session starting.
! 2015.01.03 07:58:38 - Checking environment
I 2015.01.03 07:58:38 - DNS of a network adapter forced (Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC)
! 2015.01.03 07:58:38 - Checking authorization ...
! 2015.01.03 07:58:39 - Connecting to Nashira (United Kingdom, Manchester)
. 2015.01.03 07:58:39 - SSL > stunnel 4.56 on x86-pc-mingw32-gnu platform
. 2015.01.03 07:58:39 - SSL > Compiled/running with OpenSSL 1.0.1g 7 Apr 2014
. 2015.01.03 07:58:39 - SSL > Threading:WIN32 Sockets:SELECT,IPv6 SSL:ENGINE,OCSP
. 2015.01.03 07:58:39 - SSL > Reading configuration from file C:\Users\Chris\AppData\Local\AirVPN\5add6aa9b0c5444786dbb447ad8cd003f2c8698f41c9b46a943ce54340d6a15b.tmp.ssl
. 2015.01.03 07:58:39 - SSL > Initializing service [openvpn]
. 2015.01.03 07:58:39 - SSL > Configuration successful
. 2015.01.03 07:58:39 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Oct 18 2014
. 2015.01.03 07:58:39 - OpenVPN > library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.05
. 2015.01.03 07:58:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2015.01.03 07:58:41 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.01.03 07:58:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:58:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:58:41 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.01.03 07:58:41 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:47882 [nonblock]
. 2015.01.03 07:58:41 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:47882
. 2015.01.03 07:58:41 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.01.03 07:58:41 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:47882
. 2015.01.03 07:58:41 - SSL > Service [openvpn] accepted connection from 127.0.0.1:63310
. 2015.01.03 07:58:41 - SSL > connect_blocking: connecting 84.39.116.181:443
. 2015.01.03 07:58:41 - SSL > connect_blocking: connected 84.39.116.181:443
. 2015.01.03 07:58:41 - SSL > Service [openvpn] connected remote server from 192.168.1.1:63311
. 2015.01.03 07:58:41 - SSL > SSL connected: new session negotiated
. 2015.01.03 07:58:41 - SSL > Negotiated TLSv1/SSLv3 ciphersuite: ECDHE-RSA-RC4-SHA (128-bit encryption)
. 2015.01.03 07:58:41 - SSL > Compression: null, expansion: null
. 2015.01.03 07:58:41 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:47882, sid=1aa4a778 223f31e8
. 2015.01.03 07:58:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.01.03 07:58:42 - OpenVPN > Validating certificate key usage
. 2015.01.03 07:58:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.01.03 07:58:42 - OpenVPN > VERIFY KU OK
. 2015.01.03 07:58:42 - OpenVPN > Validating certificate extended key usage
. 2015.01.03 07:58:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.01.03 07:58:42 - OpenVPN > VERIFY EKU OK
. 2015.01.03 07:58:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.01.03 07:58:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.01.03 07:58:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:58:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.01.03 07:58:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:58:43 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.01.03 07:58:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:47882
. 2015.01.03 07:58:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.01.03 07:58:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.50.0.1,comp-lzo no,route 10.50.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.50.2.226 10.50.2.225'
. 2015.01.03 07:58:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.01.03 07:58:46 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.01.03 07:58:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.01.03 07:58:46 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.01.03 07:58:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.01.03 07:58:46 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.01.03 07:58:46 - OpenVPN > open_tun, tt->ipv6=0
. 2015.01.03 07:58:46 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{5A405FF1-D4F5-4053-8759-65129C19D846}.tap
. 2015.01.03 07:58:46 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.01.03 07:58:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.2.226/255.255.255.252 on interface {5A405FF1-D4F5-4053-8759-65129C19D846} [DHCP-serv: 10.50.2.225, lease-time: 31536000]
. 2015.01.03 07:58:46 - OpenVPN > Successful ARP Flush on interface [22] {5A405FF1-D4F5-4053-8759-65129C19D846}
. 2015.01.03 07:58:51 - OpenVPN > TEST ROUTES: 3/3 succeeded len=2 ret=1 a=0 u/d=up
. 2015.01.03 07:58:51 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2015.01.03 07:58:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2015.01.03 07:58:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.01.03 07:58:51 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.2.225
. 2015.01.03 07:58:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.01.03 07:58:51 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.2.225
. 2015.01.03 07:58:51 - OpenVPN > C:\Windows\system32\route.exe ADD 84.39.116.181 MASK 255.255.255.255 192.168.1.254
. 2015.01.03 07:58:51 - OpenVPN > C:\Windows\system32\route.exe ADD 10.50.0.1 MASK 255.255.255.255 10.50.2.225
. 2015.01.03 07:58:51 - Starting Management Interface
. 2015.01.03 07:58:51 - OpenVPN > Initialization Sequence Completed
! 2015.01.03 07:58:51 - Flushing DNS
! 2015.01.03 07:58:53 - Checking route
! 2015.01.03 07:58:54 - Checking DNS
E 2015.01.03 07:58:55 - DNS checking failed.
. 2015.01.03 07:58:55 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101
! 2015.01.03 07:58:55 - Disconnecting
. 2015.01.03 07:58:55 - Management - Send 'signal SIGTERM'
. 2015.01.03 07:58:55 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.01.03 07:58:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.01.03 07:58:55 - SSL > readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2015.01.03 07:58:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 10.50.0.1 MASK 255.255.255.255 10.50.2.225
. 2015.01.03 07:58:55 - SSL > Connection reset: 11686 byte(s) sent to SSL, 9389 byte(s) sent to socket
. 2015.01.03 07:58:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.01.03 07:58:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 84.39.116.181 MASK 255.255.255.255 192.168.1.254
. 2015.01.03 07:58:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2015.01.03 07:58:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.2.225
. 2015.01.03 07:58:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.2.225
. 2015.01.03 07:58:55 - OpenVPN > Closing TUN/TAP interface
. 2015.01.03 07:58:55 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2015.01.03 07:58:55 - Connection terminated.
! 2015.01.03 07:58:58 - Checking authorization ...
! 2015.01.03 07:58:59 - Connecting to Nashira (United Kingdom, Manchester)
. 2015.01.03 07:58:59 - SSL > stunnel 4.56 on x86-pc-mingw32-gnu platform
. 2015.01.03 07:58:59 - SSL > Compiled/running with OpenSSL 1.0.1g 7 Apr 2014
. 2015.01.03 07:58:59 - SSL > Threading:WIN32 Sockets:SELECT,IPv6 SSL:ENGINE,OCSP
. 2015.01.03 07:58:59 - SSL > Reading configuration from file C:\Users\Chris\AppData\Local\AirVPN\1fc84b0ea3d4ba6be0486806a7092657fa23c3dc94b3ff3cc7cc018d083487ed.tmp.ssl
. 2015.01.03 07:58:59 - SSL > Initializing service [openvpn]
. 2015.01.03 07:58:59 - SSL > Configuration successful
. 2015.01.03 07:58:59 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Oct 18 2014
. 2015.01.03 07:58:59 - OpenVPN > library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.05
. 2015.01.03 07:58:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2015.01.03 07:58:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.01.03 07:58:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:58:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:58:59 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.01.03 07:58:59 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:57891 [nonblock]
. 2015.01.03 07:58:59 - SSL > Service [openvpn] accepted connection from 127.0.0.1:63321
. 2015.01.03 07:58:59 - SSL > connect_blocking: connecting 84.39.116.181:443
. 2015.01.03 07:58:59 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:57891
. 2015.01.03 07:58:59 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.01.03 07:58:59 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:57891
. 2015.01.03 07:59:00 - SSL > connect_blocking: connected 84.39.116.181:443
. 2015.01.03 07:59:00 - SSL > Service [openvpn] connected remote server from 192.168.1.1:63322
. 2015.01.03 07:59:00 - SSL > SSL connected: new session negotiated
. 2015.01.03 07:59:00 - SSL > Negotiated TLSv1/SSLv3 ciphersuite: ECDHE-RSA-RC4-SHA (128-bit encryption)
. 2015.01.03 07:59:00 - SSL > Compression: null, expansion: null
. 2015.01.03 07:59:00 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:57891, sid=30319c46 d5361561
. 2015.01.03 07:59:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.01.03 07:59:00 - OpenVPN > Validating certificate key usage
. 2015.01.03 07:59:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.01.03 07:59:00 - OpenVPN > VERIFY KU OK
. 2015.01.03 07:59:00 - OpenVPN > Validating certificate extended key usage
. 2015.01.03 07:59:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.01.03 07:59:00 - OpenVPN > VERIFY EKU OK
. 2015.01.03 07:59:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.01.03 07:59:02 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.01.03 07:59:02 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:59:02 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.01.03 07:59:02 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.01.03 07:59:02 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.01.03 07:59:02 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:57891
. 2015.01.03 07:59:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.01.03 07:59:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.50.0.1,comp-lzo no,route 10.50.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.50.2.226 10.50.2.225'
. 2015.01.03 07:59:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.01.03 07:59:04 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.01.03 07:59:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.01.03 07:59:04 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.01.03 07:59:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.01.03 07:59:04 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.01.03 07:58:39 - SSL > Reading configuration from file AppData\Local\AirVPN\5add6aa9b0c5444786dbb447ad8cd003f2c8698f41c9b46a943ce54340d6a15b.tmp.ssl
