ishap 4 Posted ... trakt.tv and thetvdb.com does not allow api calls on the Nashira server and through the web browser it requires a captcha for access. Quote Share this post Link to post
dontcare123 0 Posted ... Which makes Sick-Beard, the main reason I use AirVPN, useless. Quote Share this post Link to post
DudeGannivelka 2 Posted ... Same for me, I'm using AirVPN to hide the activity of my Synology Server and it is also blacklisted for server Nunki in Great Britain too... So I can't use sickrage and AirVPN at the same time... Quote Share this post Link to post
DudeGannivelka 2 Posted ... For information, if you are running AirVPN on a Linux based system (in my case Synology), you can perform the following command as root (for Synology ssh into it) for both thetvdb and trakt.tv (this means you will connect to this site with your real WAN ip adress tho) and if 192.168.1.1 is the ip adress of your local gateway. ip route add 141.101.123.81 via 192.168.1.1 dev eth0ip route add 141.101.113.81 via 192.168.1.1 dev eth0ip route add 190.93.241.81 via 192.168.1.1 dev eth0ip route add 190.93.240.81 via 192.168.1.1 dev eth0ip route add 190.93.242.81 via 192.168.1.1 dev eth0ip route add 198.41.204.42 via 192.168.1.1 dev eth0ip route add 198.41.205.42 via 192.168.1.1 dev eth0 Quote Share this post Link to post
patchcableuk 0 Posted ... I have the same problem, took a while to realise this was the issue. Noticing more hosting services catching up and 'blocking' airvpn. Nature of the beast when sharing the service with users who have more sinister motives (spammers etc.) All good things must come to an end though i suppose? Quote Share this post Link to post
M0UL 0 Posted ... this is caused by cloudflare not by trakt.tv and thetvdb.com Quote Share this post Link to post
flat4 95 Posted ... Damn I use sickrage And I going to build a pfSense box. Have you tried my of the American servers. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
