PaulPunkGTX
Can't Port Forward
Hey guys,
my problem is that i want to port forward some ports
TCP: 80, 443
UDP: 3658, 13000-13032
TCP: 13000, 13005, 13200
TCP & UDP: 11155
But when i try to do this, it tells me, that this port is already reserved by another user! How do i fix this?
You need to use other ports and forward them on your router to the correct one. (that's not optimal i think but it works)
