mrblurayman
airvpn lock help
yes I read this but don't understand the box do I type in it ?
IF I pick isp USA OR UK FRANCE and my connections will vuze close ? and any web pages close ?
as I did test earlier today and it did not work for me I am finding this hard sorry and thinking of going else where sorry as I cant get my head round it I did ask friend to help but he was lost with also.
im sorry but I cant really fully understand it
If you are on windows, then I would highly suggest a program called VPNCheck. When I was running Windows and AirVPN this program worked great. This program does what you want it to. It will close all programs you specify. Such as Vuze, browser, anything that you want to close it will. I will leave links for the prgoram and setup below. Get the free version. PThe directions are for the pro version but it works the same way with the free version.
http://www.guavi.com/vpncheck_free.html
http://jasonpitts.com/privacy/vpncheck-pro-keep-your-vpn-connected-when-you-need-it-using-vpn-check-pro/
This setup worked well for me for quite a long time. Enjoy!
Hi thanks for help id love to stay speeds are great.But im shite at trying set up this vpncheck kill switch and dns leak I have no clue sorry.Its a shame id don't have some friends live near me that could set this all up and running and test for me as I would be happy to pay some cash to set this up for me.Thank u
Just close ALL of your programs, Everything.
Start up the Airvpn client.
Make sure the lock option is activated.
"You can activate it in Menu > Preferences > Advanced > Network Lock
After any change, do not forget to click the "Save" button.
Our software adopts various approaches to perform a network lock according to the operating system, software already available etc"
https://airvpn.org/faq/software_lock/?do=findComment&comment=20070
Click connect.
-surf
