Not connected, Your IP: 216.73.216.44
tammo
Luxembourg & spain gateway not working ...
since yesterday (or a few days) the luxembourg server is not working ... I can login, but there are strange messages when the connection is established with openVPN.
For example:
Wed Oct 29 15:44:31 2014 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.72.94 10.4.72.93'
(I won't post the whole entry, because of my IP and other private things in there.)
The other gateways work as always, except ES-Sador (spain) -> there's no login possible (openVPN says always "STATE:1414594758,WAIT,,,").
I did no changes in my config files or anywhere else.
Can anyone confirm that that these two servers do not work?
And does anyone know perhaps some details ...
Thanks for answering. As you can imagine, I have not used the spanish server for a long time, otherwise I would have known ... but Nihal is working! So that's done!
But Luxembourg (Herculis) is still not working!
You're welcome.
Herculis is still down, but I assume staff are working on a fix. It's the only Luxembourg server, so it would be good to get it back. You do know that you can check the status of all the servers by checking the status page on this website, right?
