Not connected, Your IP: 216.73.216.190
lokiynk
Trouble with Eddie client under Kali (Debian)
I have some severe problems getting the Air client installed in Kali Linux, which should be derived from Debian actually.
I am always getting these error when I try to install the client, I tried 2.6 and 2.7 :
"GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._pk_5ftransaction_5ferror.Code4: SimulateInstallFiles not supported by backend"
I then tried the mobile version, which also doesn't work at all, when I try to start it I get the following errors, I tried as user and root :
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Native.Syscall ---> System.DllNotFoundException: ./libMonoPosixHelper.so
  at (wrapper managed-to-native) Mono.Unix.Native.Syscall:_L_ctermid ()
  at Mono.Unix.Native.Syscall..cctor () [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at AirVPN.Platforms.Linux.GetExecutablePath () [0x00000] in <filename unknown>:0
  at AirVPN.Core.Platform.GetProgramFolder () [0x00000] in <filename unknown>:0
  at AirVPN.Core.Engine.Initialization () [0x00000] in <filename unknown>:0
  at AirVPN.UI.Linux.Program.Main () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Native.Syscall ---> System.DllNotFoundException: ./libMonoPosixHelper.so
I am mainly connecting in all my linux installations from command line, which is also working fine from the Kali installation. So why do I need the client? It is because I am using it for the new features for IPTables lock, this means I am just starting the client for the firewall rules and am doing the connections by hand then.
Can you please help me to fix these issues in order to get the client work in Kali?
What I did as a workaround until this is cleared is that I did an iptables-save in my Mint installation where the client is working fine. I then took the saved file over to my Kali installation and changed the iptables through a iptables-restore. This just seemed to work, iptables -S is showing the correct configuration with all the Air servers in it. But it is still a workaround and not very comfortable so I would be pleased to get feedback if this can be fixed or the client can't be used in Kali at all.
Thanks!
We just installed a Kali 64 bit fresh system under Virtualbox.
We encountered the error 'SimulateInstallFiles not supported by backend' with the .deb file.
From a root terminal, please run:
# apt-get install mono-runtime
we needed also to run a
# apt-get -f install
and to install AirVPN Client:
# dpkg -i airvpn_linux_x64_debian.deb
You can find the AirVPN icon in 'Internet' menù.
Please confirm to us if it works, we would like to add Kali in our supported environments.
this worked like a charm now. Thanks a lot.
I didn't try the whole functionality of the client as I am doing the connections manually as I wrote already.
But the install works, it can be started and the iptables lock is also working perfectly, so I suppose the rest will work, too.
Cheers!
I got error processing airvpn (--install) : dependency problems - leaving unconfigured
I'm new to Linux I'm not really sure how to fix that
I'm trying the same as above but it says:
"dpkg: error processing airvpn_linux_x64_debian.deb (--install):
 cannot access archive: No such file or directory"
Any suggestions?
I am having exactly the problem described here on an x86 computer running the latest version of kali linux. Followed the steps exactly with exception that I am using the x86 version of Eddie.
Any help available? I have previously been successful installing on a 64 bit kali linux.
I've exactement le same problem. Is there a solution to resolve it ? Thanks  lot. bestway@sigaintorg
Install all the required packages first. Please see here for a complete list of dependencies:
https://airvpn.org/topic/12509-kali
Thanks you very much ! I 've install airvpn following your help. But......but I can't connect and I don't know why. I 've copy the log of connection if you could please help me.
I 2015.06.01 14:06:16 - AirVPN client version: 2.9.2, System: Linux, Name: Kali GNU/Linux 1.1.0 \n \l, Architecture: x86
. 2015.06.01 14:06:16 - Reading options from /root/.airvpn/AirVPN.xml
. 2015.06.01 14:06:19 - Data Path: /root/.airvpn
. 2015.06.01 14:06:19 - App Path: /usr/lib/AirVPN
. 2015.06.01 14:06:19 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2015.06.01 14:06:19 - Command line arguments (1): path="/root/.airvpn"
. 2015.06.01 14:06:19 - Updating systems & servers data ...
. 2015.06.01 14:06:19 - Operating System: Unix 3.18.0.3 - Linux root 3.18.0-kali3-686-pae #1 SMP Debian 3.18.6-1~kali2 (2015-03-02) i686 GNU/Linux
I 2015.06.01 14:06:20 - OpenVPN Driver - Found, /dev/net/tun
I 2015.06.01 14:06:20 - OpenVPN - Version: OpenVPN 2.2.1 (/usr/sbin/openvpn)
I 2015.06.01 14:06:20 - SSH - Version: OpenSSH_6.0p1 Debian-4+deb7u2, OpenSSL 1.0.1e 11 Feb 2013 (/usr/bin/ssh)
I 2015.06.01 14:06:20 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
! 2015.06.01 14:06:20 - Ready
. 2015.06.01 14:06:26 - Systems & servers data update completed
! 2015.06.01 14:07:05 - Activation of Network Lock - Linux IPTables
! 2015.06.01 14:07:47 - Deactivation of Network Lock
. 2015.06.01 14:09:08 - Updating systems & servers data ...
. 2015.06.01 14:09:10 - Systems & servers data update completed
I 2015.06.01 14:09:52 - Session starting.
I 2015.06.01 14:09:53 - Checking authorization ...
! 2015.06.01 14:09:54 - Connecting to Cygni (Sweden, Stockholm)
. 2015.06.01 14:09:54 - OpenVPN > OpenVPN 2.2.1 i486-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Dec  1 2014
. 2015.06.01 14:09:54 - OpenVPN > RESOLVE: NOTE: localhost resolves to 2 addresses
. 2015.06.01 14:09:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.06.01 14:09:54 - OpenVPN > NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
. 2015.06.01 14:09:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.06.01 14:09:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.06.01 14:09:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.06.01 14:09:54 - OpenVPN > LZO compression initialized
. 2015.06.01 14:09:54 - OpenVPN > Control Channel MTU parms [ L:1558 D:166 EF:66 EB:0 ET:0 EL:0 ]
. 2015.06.01 14:09:54 - OpenVPN > Socket Buffers: R=[163840->131072] S=[163840->131072]
. 2015.06.01 14:09:54 - OpenVPN > Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
. 2015.06.01 14:09:54 - OpenVPN > Local Options hash (VER=V4): '9e7066d2'
. 2015.06.01 14:09:54 - OpenVPN > Expected Remote Options hash (VER=V4): '162b04de'
. 2015.06.01 14:09:54 - OpenVPN > UDPv4 link local: [undef]
. 2015.06.01 14:09:54 - OpenVPN > UDPv4 link remote: [AF_INET]94.185.85.170:443
. 2015.06.01 14:10:26 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.06.01 14:10:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.06.01 14:10:31 - OpenVPN > TCP/UDP: Closing socket
. 2015.06.01 14:10:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.06.01 14:10:31 - Disconnecting
. 2015.06.01 14:10:31 - Connection terminated.
I 2015.06.01 14:10:34 - Checking authorization ...
! 2015.06.01 14:10:35 - Connecting to Cygni (Sweden, Stockholm)
. 2015.06.01 14:10:35 - OpenVPN > OpenVPN 2.2.1 i486-linux-gnu [sSL]
.....and again and again..never  stops
The problem is here:
Please make sure that your router firewall does not block UDP packets (system firewall should be fine because you have Network Lock activated).
In case it's your ISP to block UDP (rare but not impossible), try a connection in TCP. You can change connection protocol in client menu/tab "AirVPN" -> "Preferences" -> "Protocols".
