Annonnymous
Failure in connection / Constant reconnections
Hey guys I have an issue with my connection I just can't figure out what it is. The problem seems to be in here
"2014.10.20 20:53:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
but I can't fix it any suggestions? I tried it with eddie and openvpn gui
2014.10.20 20:52:49 - AirVPN client version: 2.7, System: Windows, Architecture: x64
. 2014.10.20 20:52:49 - Reading options from C:\Program Files\AirVPN\AirVPN.xml
. 2014.10.20 20:52:49 - Data Path: C:\Program Files\AirVPN
. 2014.10.20 20:52:49 - App Path: C:\Program Files\AirVPN
. 2014.10.20 20:52:49 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2014.10.20 20:52:49 - Command line arguments:
. 2014.10.20 20:52:49 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2014.10.20 20:52:49 - OpenVPN Driver - TAP-Windows Adapter V9
I 2014.10.20 20:52:49 - OpenVPN - Version: OpenVPN 2.3.4 (C:\Program Files\AirVPN\openvpn.exe)
I 2014.10.20 20:52:49 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2014.10.20 20:52:49 - SSL - Version: stunnel 4.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2014.10.20 20:52:49 - IPV6: Available
. 2014.10.20 20:52:49 - Updating systems & servers data ...
! 2014.10.20 20:52:49 - Activation of Network Lock - Windows Firewall
. 2014.10.20 20:52:50 - Systems & servers data update completed
I 2014.10.20 20:52:53 - Session starting.
! 2014.10.20 20:52:53 - Checking environment
I 2014.10.20 20:52:53 - Network adapter DHCP switched to static (Intel® Centrino® Advanced-N 6205)
I 2014.10.20 20:52:57 - DNS of a network adapter forced (Intel® Centrino® Advanced-N 6205)
! 2014.10.20 20:52:57 - Waiting for latency tests (60 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (54 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (47 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (41 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (37 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (31 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (27 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (21 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (17 to go)
! 2014.10.20 20:52:58 - Waiting for latency tests (13 to go)
! 2014.10.20 20:52:59 - Waiting for latency tests (11 to go)
! 2014.10.20 20:52:59 - Waiting for latency tests (9 to go)
! 2014.10.20 20:52:59 - Waiting for latency tests (5 to go)
! 2014.10.20 20:52:59 - Checking authorization ...
! 2014.10.20 20:52:59 - Connecting to Wezen (Germany, Frankfurt)
. 2014.10.20 20:52:59 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 18 2014
. 2014.10.20 20:52:59 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.10.20 20:52:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2014.10.20 20:53:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.10.20 20:53:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.20 20:53:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.20 20:53:00 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2014.10.20 20:53:00 - OpenVPN > UDPv4 link local: [undef]
. 2014.10.20 20:53:00 - OpenVPN > UDPv4 link remote: [AF_INET]178.162.198.112:80
. 2014.10.20 20:53:00 - OpenVPN > TLS: Initial packet from [AF_INET]178.162.198.112:80, sid=f663e84b 92cc1e7e
. 2014.10.20 20:53:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.10.20 20:53:00 - OpenVPN > Validating certificate key usage
. 2014.10.20 20:53:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.10.20 20:53:00 - OpenVPN > VERIFY KU OK
. 2014.10.20 20:53:00 - OpenVPN > Validating certificate extended key usage
. 2014.10.20 20:53:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.10.20 20:53:00 - OpenVPN > VERIFY EKU OK
. 2014.10.20 20:53:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.10.20 20:53:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.10.20 20:53:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.20 20:53:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.10.20 20:53:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.20 20:53:01 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.10.20 20:53:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]178.162.198.112:80
. 2014.10.20 20:53:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.10.20 20:53:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.6.0.1,comp-lzo no,route 10.6.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.6.1.82 10.6.1.81'
. 2014.10.20 20:53:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.10.20 20:53:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.10.20 20:53:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.10.20 20:53:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.10.20 20:53:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.10.20 20:53:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.10.20 20:53:03 - OpenVPN > open_tun, tt->ipv6=0
. 2014.10.20 20:53:03 - OpenVPN > TAP-WIN32 device [LAN-Verbindung 3] opened: \\.\Global\{F70ECFC4-89E9-4F32-9530-D71E194551BE}.tap
. 2014.10.20 20:53:03 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.10.20 20:53:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.1.82/255.255.255.252 on interface {F70ECFC4-89E9-4F32-9530-D71E194551BE} [DHCP-serv: 10.6.1.81, lease-time: 31536000]
. 2014.10.20 20:53:03 - OpenVPN > Successful ARP Flush on interface [18] {F70ECFC4-89E9-4F32-9530-D71E194551BE}
. 2014.10.20 20:53:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:08 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:14 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:15 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:16 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:17 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:18 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:19 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:20 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:21 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:23 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:24 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:25 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:27 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:28 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:29 - AirVPN Windows Interface Hack executed (LAN-Verbindung 3)
. 2014.10.20 20:53:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.10.20 20:53:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.10.20 20:53:38 - OpenVPN > C:\Windows\system32\route.exe ADD 178.162.198.112 MASK 255.255.255.255 192.168.178.1
. 2014.10.20 20:53:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2014.10.20 20:53:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2014.10.20 20:53:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.1.81
. 2014.10.20 20:53:38 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.6.1.81
. 2014.10.20 20:53:38 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2014.10.20 20:53:38 - OpenVPN > Route addition fallback to route.exe
. 2014.10.20 20:53:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2014.10.20 20:53:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.1.81
. 2014.10.20 20:53:38 - OpenVPN > C:\Windows\system32\route.exe ADD 10.6.0.1 MASK 255.255.255.255 10.6.1.81
. 2014.10.20 20:53:39 - OpenVPN > SYSTEM ROUTING TABLE
. 2014.10.20 20:53:39 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.178.1 p=0 i=14 t=4 pr=3 a=45 h=0 m=21/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 0.0.0.0 128.0.0.0 10.6.1.81 p=0 i=14 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 10.6.0.1 255.255.255.255 10.6.1.81 p=0 i=14 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 10.7.5.44 255.255.255.252 10.7.5.46 p=0 i=18 t=3 pr=3 a=8370 h=0 m=286/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 10.7.5.46 255.255.255.255 10.7.5.46 p=0 i=18 t=3 pr=3 a=8370 h=0 m=286/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 10.7.5.47 255.255.255.255 10.7.5.46 p=0 i=18 t=3 pr=3 a=8370 h=0 m=286/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=8805 h=0 m=306/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=8805 h=0 m=306/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=8805 h=0 m=306/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 128.0.0.0 128.0.0.0 10.6.1.81 p=0 i=14 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 178.162.198.112 255.255.255.255 192.168.178.1 p=0 i=14 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 192.168.178.0 255.255.255.0 192.168.178.39 p=0 i=14 t=3 pr=3 a=42 h=0 m=276/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 192.168.178.39 255.255.255.255 192.168.178.39 p=0 i=14 t=3 pr=3 a=42 h=0 m=276/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 192.168.178.255 255.255.255.255 192.168.178.39 p=0 i=14 t=3 pr=3 a=42 h=0 m=276/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=8805 h=0 m=306/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 224.0.0.0 240.0.0.0 10.7.5.46 p=0 i=18 t=3 pr=3 a=8791 h=0 m=286/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.178.39 p=0 i=14 t=3 pr=3 a=8470 h=0 m=276/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=8805 h=0 m=306/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 255.255.255.255 255.255.255.255 10.7.5.46 p=0 i=18 t=3 pr=3 a=8791 h=0 m=286/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.178.39 p=0 i=14 t=3 pr=3 a=8470 h=0 m=276/0/0/0/0
. 2014.10.20 20:53:39 - OpenVPN > SYSTEM ADAPTER LIST
. 2014.10.20 20:53:39 - OpenVPN > TAP-Windows Adapter V9
. 2014.10.20 20:53:39 - OpenVPN >   Index = 18
. 2014.10.20 20:53:39 - OpenVPN >   GUID = {F70ECFC4-89E9-4F32-9530-D71E194551BE}
. 2014.10.20 20:53:39 - OpenVPN >   IP = 10.7.5.46/255.255.255.252
. 2014.10.20 20:53:39 - OpenVPN >   MAC = 00:ff:f7:0e:cf:c4
. 2014.10.20 20:53:39 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2014.10.20 20:53:39 - OpenVPN >   DHCP SERV = 10.7.5.45/255.255.255.255
. 2014.10.20 20:53:39 - OpenVPN >   DHCP LEASE OBTAINED = Mon Oct 20 18:34:08 2014
. 2014.10.20 20:53:39 - OpenVPN >   DHCP LEASE EXPIRES  = Tue Oct 20 18:34:08 2015
. 2014.10.20 20:53:39 - OpenVPN >   DNS SERV = 10.7.0.1/255.255.255.255
. 2014.10.20 20:53:39 - OpenVPN > Microsoft Virtual WiFi Miniport Adapter #2
. 2014.10.20 20:53:39 - OpenVPN >   Index = 16
. 2014.10.20 20:53:39 - OpenVPN >   GUID = {9AA5CF21-7318-4589-B7F1-B5B02DF98663}
. 2014.10.20 20:53:39 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2014.10.20 20:53:39 - OpenVPN >   MAC = 10:0b:a9:2c:1a:9d
. 2014.10.20 20:53:39 - OpenVPN >   DHCP LEASE OBTAINED = Mon Oct 20 20:53:39 2014
. 2014.10.20 20:53:39 - OpenVPN >   DHCP LEASE EXPIRES  = Mon Oct 20 20:53:39 2014
. 2014.10.20 20:53:39 - OpenVPN >   Index = 15
. 2014.10.20 20:53:39 - OpenVPN >   GUID = {61033696-B5E4-4F66-86D8-5CA956910074}
. 2014.10.20 20:53:39 - OpenVPN > Intel® Centrino® Advanced-N 6205
. 2014.10.20 20:53:39 - OpenVPN >   Index = 14
. 2014.10.20 20:53:39 - OpenVPN >   GUID = {AF7FB857-6AF0-409D-BA35-C706035AE9E9}
. 2014.10.20 20:53:39 - OpenVPN >   IP = 192.168.178.39/255.255.255.0
. 2014.10.20 20:53:39 - OpenVPN >   MAC = 10:0b:a9:2c:1a:9c
. 2014.10.20 20:53:39 - OpenVPN >   GATEWAY = 192.168.178.1/255.255.255.255
. 2014.10.20 20:53:39 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2014.10.20 20:53:39 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
. 2014.10.20 20:53:39 - OpenVPN >   Index = 11
. 2014.10.20 20:53:39 - OpenVPN >   GUID = {121A33B0-8B1E-4381-9ABE-9C4E8A9C96D1}
. 2014.10.20 20:53:39 - OpenVPN >   MAC = b8:88:e3:55:44:6f
. 2014.10.20 20:53:39 - Starting Management Interface
. 2014.10.20 20:53:39 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2014.10.20 20:53:39 - Flushing DNS
. 2014.10.20 20:53:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101
! 2014.10.20 20:53:39 - Disconnecting
. 2014.10.20 20:53:39 - Management - Send 'signal SIGTERM'
. 2014.10.20 20:53:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2014.10.20 20:53:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2014.10.20 20:53:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2014.10.20 20:53:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 10.6.0.1 MASK 255.255.255.255 10.6.1.81
. 2014.10.20 20:53:44 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.6.1.81
. 2014.10.20 20:53:44 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2014.10.20 20:53:44 - OpenVPN > Route deletion fallback to route.exe
. 2014.10.20 20:53:44 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2014.10.20 20:53:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 178.162.198.112 MASK 255.255.255.255 192.168.178.1
. 2014.10.20 20:53:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2014.10.20 20:53:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.1.81
. 2014.10.20 20:53:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.1.81
. 2014.10.20 20:53:44 - OpenVPN > Closing TUN/TAP interface
. 2014.10.20 20:53:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2014.10.20 20:53:44 - Connection terminated.
I 2014.10.20 20:53:47 - Cancel requested.
I 2014.10.20 20:53:47 - DNS of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6205)
I 2014.10.20 20:53:52 - DHCP of a network adapter restored to original settings (Intel® Centrino® Advanced-N 6205)
! 2014.10.20 20:53:52 - Session terminated.
Hello guys I cannot post in How/to but I am hoping that you will do that if I answer to this problem with the soloution :-D
I have had the exact same issue on windows 7 x64 which was reportedly only known on windows 8/8.1
After doing a lot of research on the internet, these are the soloutions that got it working again.
First:
go to device manager => network devices => Tap Windows Adapter => Properties => Advanced => Media Status => and than change the value to always connected
Second:
go to network adapters => the tap adaoter should be shown as a lan connection for me it is 3 => Properties => deactivate Ipv6
This is a collection of what worked for me however these two things are reportedly working for other people
Before you start the client of openvpn or arivpn open your network and sharing center and than start your client (no idea why but for some people this fixes the issue)
And last but not least the program securepoint openvpn is supposed to fix the problem as well.
I hope one of these soloutions will help you
