asus27
iMac OSX Yosemite and crash
Okay, so I purchased AirVPN 3.4.1(4054) and cannot for the life of me get it to work!?? I am using a Mac, Software  OS X 10.10 Yosemite and can log into AirVPN program as downloaded from the site but cannot connect to a single server as it continually authenticates and then restarts and this is all it does.
Any help would be greatly appreciated!
Thanks, Fabrice
2014-10-18 16:26:47 *Tunnelblick: OS X 10.10.0; Tunnelblick 3.4.1 (build 4054); prior version 3.4.0 (build 4007)
2014-10-18 16:26:48 *Tunnelblick: Attempting connection with Allemagne; Set nameserver = 1; monitoring connection
2014-10-18 16:26:48 *Tunnelblick: openvpnstart start Allemagne.tblk 1337 1 0 3 0 16688 -ptADGNWradsgnw 2.3.4
2014-10-18 16:26:48 *Tunnelblick: openvpnstart log:
     Tunnelblick:
     OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
          /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3.4/openvpn
          --daemon
          --log
          /Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-SAllemagne.tblk-SContents-SResources-Sconfig.ovpn.1_0_3_0_16688.1337.openvpn.log
          --cd
          /Library/Application Support/Tunnelblick/Shared/Allemagne.tblk/Contents/Resources
          --config
          /Library/Application Support/Tunnelblick/Shared/Allemagne.tblk/Contents/Resources/config.ovpn
          --cd
          --management
          127.0.0.1
          1337
          --management-query-passwords
          --management-hold
          --script-security
          2
          --up
          /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -ptADGNWradsgnw
          --down
          /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -ptADGNWradsgnw
2014-10-18 16:26:48 *Tunnelblick: Established communication with OpenVPN
2014-10-18 16:26:48 OpenVPN 2.3.4 x86_64-apple-darwin [sSL (OpenSSL)] [LZO] [PKCS11] [MH] [iPv6] built on Oct 15 2014
2014-10-18 16:26:48 library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.08
2014-10-18 16:26:48 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2014-10-18 16:26:48 Need hold release from management interface, waiting...
2014-10-18 16:26:48 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2014-10-18 16:26:48 MANAGEMENT: CMD 'pid'
2014-10-18 16:26:48 MANAGEMENT: CMD 'state on'
2014-10-18 16:26:48 MANAGEMENT: CMD 'state'
2014-10-18 16:26:48 MANAGEMENT: CMD 'bytecount 1'
2014-10-18 16:26:48 MANAGEMENT: CMD 'hold release'
2014-10-18 16:26:48 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2014-10-18 16:26:48 Control Channel Authentication: tls-auth using INLINE static key file
2014-10-18 16:26:48 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2014-10-18 16:26:48 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2014-10-18 16:26:48 Socket Buffers: R=[196724->65536] S=[9216->65536]
2014-10-18 16:26:48 MANAGEMENT: >STATE:1413642408,RESOLVE,,,
2014-10-18 16:26:48 UDPv4 link local: [undef]
2014-10-18 16:26:48 UDPv4 link remote: [AF_INET]46.165.208.70:443
2014-10-18 16:26:48 MANAGEMENT: >STATE:1413642408,WAIT,,,
2014-10-18 16:26:48 MANAGEMENT: >STATE:1413642408,AUTH,,,
2014-10-18 16:26:48 TLS: Initial packet from [AF_INET]46.165.208.70:443, sid=a8d7f830 5396c740
2014-10-18 16:26:48 *Tunnelblick: openvpnstart starting OpenVPN
2014-10-18 16:26:54 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2014-10-18 16:26:54 Validating certificate key usage
2014-10-18 16:26:54 ++ Certificate has key usage  00a0, expects 00a0
2014-10-18 16:26:54 VERIFY KU OK
2014-10-18 16:26:54 Validating certificate extended key usage
2014-10-18 16:26:54 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2014-10-18 16:26:54 VERIFY EKU OK
2014-10-18 16:26:54 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
2014-10-18 16:27:00 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2014-10-18 16:27:00 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2014-10-18 16:27:00 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2014-10-18 16:27:00 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2014-10-18 16:27:00 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
2014-10-18 16:27:00 [server] Peer Connection Initiated with [AF_INET]46.165.208.70:443
2014-10-18 16:27:02 MANAGEMENT: >STATE:1413642422,GET_CONFIG,,,
2014-10-18 16:27:03 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2014-10-18 16:27:03 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.83.66 10.4.83.65'
2014-10-18 16:27:03 OPTIONS IMPORT: timers and/or timeouts modified
2014-10-18 16:27:03 OPTIONS IMPORT: LZO parms modified
2014-10-18 16:27:03 OPTIONS IMPORT: --ifconfig/up options modified
2014-10-18 16:27:03 OPTIONS IMPORT: route options modified
2014-10-18 16:27:03 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2014-10-18 16:27:03 Opening utun (connect(AF_SYS_CONTROL)): No buffer space available
2014-10-18 16:27:03 Failed to open utun device. Falling back to /dev/tun device
2014-10-18 16:27:03 MANAGEMENT: Client disconnected
2014-10-18 16:27:03 Cannot allocate TUN/TAP dev dynamically
2014-10-18 16:27:03 Exiting due to fatal error
2014-10-18 16:27:04 *Tunnelblick: No 'post-disconnect.sh' script to execute
2014-10-18 16:27:04 *Tunnelblick: Expected disconnection occurred.
You did not buy "AirVPN 3.4.1(4054)", you're running Tunnelblick 3.4.1build 4054. Tunnelblick is a free and open source OpenVPN wrapper.
Yosemite is on preview so it could be normal.
Instead of Tunnelblick try to run our client Eddie 2.7: in the Yosemite preview of about 10 days ago it was running just fine. Our dear Eddie is free and open source as well.
Your English is better than my French.
At the top of the AirVPN website there are a couple tabs that read, Home, Enter, Status, Forums. Click on "Enter". Then click on "Mac OSX" and then it will take you to the page where you can download the AirVPN client.
I am using the AirVPN client on OSX Yosemite right now and it's working very well.
Good morning
With Eddie 2.7 it is the same problem  . I have installed Windows 8 in my iMac, and no problem for my connexion, it's just with Yosemite.
Repport Eddie :
. 2014.10.19 15:12:29 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): No buffer space available
. 2014.10.19 15:12:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.10.19 15:12:29 - OpenVPN > Validating certificate key usage
. 2014.10.19 15:12:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.10.19 15:12:29 - OpenVPN > VERIFY KU OK
. 2014.10.19 15:12:30 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): No buffer space available
. 2014.10.19 15:12:30 - OpenVPN > Validating certificate extended key usage
. 2014.10.19 15:12:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.10.19 15:12:30 - OpenVPN > VERIFY EKU OK
. 2014.10.19 15:12:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.10.19 15:12:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): No buffer space available
. 2014.10.19 15:12:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.10.19 15:12:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.19 15:12:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.10.19 15:12:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.10.19 15:12:31 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.10.19 15:12:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:80
. 2014.10.19 15:12:31 - OpenVPN > Failed to open utun device. Falling back to /dev/tun device
. 2014.10.19 15:12:31 - OpenVPN > Cannot allocate TUN/TAP dev dynamically
. 2014.10.19 15:12:31 - OpenVPN > Exiting due to fatal error
! 2014.10.19 15:12:31 - Disconnecting
. 2014.10.19 15:12:31 - Connection terminated.
Thank you
Fabrice
Before the AirVPN client was released I used a program called Viscosity. I have used that for almost 2 years now and it is simple and it works very well. Give that a try.
Hello from France,
Thank you for your answers, and excuse me for my English... Very bad... I have found the solution for Tunnelblick, i must check in the options "ALWAYS LOAD TUN DRIVER" and it's ok for the connection TB. with AirVPN ENJOY.
Now, i want use your client Eddie 2.7, where i can found this option in order to force to load tun driver? Indeed, Eddie doesn't work .
Bye bye everyone
