hotprobable
Mac connecting restart loop
Just got the client and bought a year's worth (wondering if I should regret this).  Stuck in the Restart in ... Can't connect to anything.
. 2014.09.30 16:27:06 - Connection terminated.
! 2014.09.30 16:27:09 - Checking authorization ...
! 2014.09.30 16:27:09 - Connecting to Naos (United Kingdom, Manchester)
. 2014.09.30 16:27:09 - OpenVPN > OpenVPN 2.3.4 x86_64-apple-darwin13.2.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 18 2014
. 2014.09.30 16:27:09 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.09.30 16:27:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.09.30 16:27:09 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.09.30 16:27:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.30 16:27:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.30 16:27:09 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2014.09.30 16:27:09 - OpenVPN > UDPv4 link local: [undef]
. 2014.09.30 16:27:09 - OpenVPN > UDPv4 link remote: [AF_INET]84.39.117.56:443
. 2014.09.30 16:27:10 - OpenVPN > TLS: Initial packet from [AF_INET]84.39.117.56:443, sid=a71e331c 21fbcc87
. 2014.09.30 16:27:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.09.30 16:27:14 - OpenVPN > Validating certificate key usage
. 2014.09.30 16:27:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.09.30 16:27:14 - OpenVPN > VERIFY KU OK
. 2014.09.30 16:27:14 - OpenVPN > Validating certificate extended key usage
. 2014.09.30 16:27:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.09.30 16:27:14 - OpenVPN > VERIFY EKU OK
. 2014.09.30 16:27:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.09.30 16:27:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.30 16:27:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.30 16:27:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.30 16:27:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.30 16:27:22 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.09.30 16:27:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]84.39.117.56:443
. 2014.09.30 16:27:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.09.30 16:27:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.92.186 10.4.92.185'
. 2014.09.30 16:27:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.09.30 16:27:25 - OpenVPN > dyld: lazy symbol binding failed: Symbol not found: ___strlcpy_chk
. 2014.09.30 16:27:25 - OpenVPN >   Referenced from: /Applications/AirVPN.app/Contents/MacOS/openvpn
. 2014.09.30 16:27:25 - OpenVPN >   Expected in: /usr/lib/libSystem.B.dylib
. 2014.09.30 16:27:25 - OpenVPN > dyld: Symbol not found: ___strlcpy_chk
. 2014.09.30 16:27:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.09.30 16:27:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.09.30 16:27:25 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.09.30 16:27:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
! 2014.09.30 16:27:25 - Disconnecting
. 2014.09.30 16:27:25 - Connection terminated.
I 2014.09.30 16:27:28 - Cancel requested.
