winstral893
Problem: AirVpn over tor and software lock
Hi I connect to air using tor, I would like to use the software lock functionality Eddie, but if I use it also blocks the connections tor, therefore you can not connect through tor using this functionality.
Will could fix this in future versions of the client Eddie?
thank you
