Not connected, Your IP: 216.73.216.14
dtsakirakis
Eddie 2.5 connects and disconnects issues
I 2014.09.15 19:12:05 - AirVPN client version: 2.5, System: Windows, Architecture: x64
. 2014.09.15 19:12:05 - Reading options from C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\AirVPN.xml
. 2014.09.15 19:12:06 - Data Path: C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable
. 2014.09.15 19:12:06 - App Path: C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable
. 2014.09.15 19:12:06 - Executable Path: C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\AirVPN.exe
. 2014.09.15 19:12:06 - Command line arguments:
. 2014.09.15 19:12:06 - Operating System: Microsoft Windows NT 6.2.9200.0
I 2014.09.15 19:12:06 - OpenVPN Driver - TAP-Windows Adapter V9
I 2014.09.15 19:12:06 - OpenVPN - Version: OpenVPN 2.3.4 (C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\openvpn.exe)
I 2014.09.15 19:12:06 - SSH - Version: plink 0.63 (C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\plink.exe)
I 2014.09.15 19:12:06 - SSL - Version: stunnel 4.56 (C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\stunnel.exe)
I 2014.09.15 19:12:06 - IPV6: Available
! 2014.09.15 19:12:06 - Activation of Network Lock - Windows Firewall
! 2014.09.15 19:12:09 - Ready
I 2014.09.15 19:12:14 - Session starting.
! 2014.09.15 19:12:14 - Checking environment
! 2014.09.15 19:12:14 - Retrieving manifest
I 2014.09.15 19:12:29 - DNS of a network adapter forced (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller)
! 2014.09.15 19:12:29 - Checking authorization
! 2014.09.15 19:12:30 - Connecting to Taygeta (Netherlands, Amsterdam)
. 2014.09.15 19:12:30 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 18 2014
. 2014.09.15 19:12:30 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.09.15 19:12:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.09.15 19:12:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.09.15 19:12:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:12:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:12:30 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2014.09.15 19:12:30 - OpenVPN > UDPv4 link local: [undef]
. 2014.09.15 19:12:30 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.6:443
. 2014.09.15 19:12:30 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.81.6:443, sid=d049a2e9 ff03549d
. 2014.09.15 19:12:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.09.15 19:12:31 - OpenVPN > Validating certificate key usage
. 2014.09.15 19:12:31 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2014.09.15 19:12:31 - OpenVPN > VERIFY KU OK
. 2014.09.15 19:12:31 - OpenVPN > Validating certificate extended key usage
. 2014.09.15 19:12:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.09.15 19:12:31 - OpenVPN > VERIFY EKU OK
. 2014.09.15 19:12:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.09.15 19:12:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.15 19:12:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:12:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.15 19:12:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:12:43 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.09.15 19:12:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.81.6:443
. 2014.09.15 19:12:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.09.15 19:12:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.95.206 10.4.95.205'
. 2014.09.15 19:12:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.09.15 19:12:45 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.09.15 19:12:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.09.15 19:12:45 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.09.15 19:12:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.09.15 19:12:45 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.09.15 19:12:45 - OpenVPN > open_tun, tt->ipv6=0
. 2014.09.15 19:12:46 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{FB74DA04-E3FB-4D6B-B5CF-22B95BB25E7A}.tap
. 2014.09.15 19:12:46 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.09.15 19:12:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.95.206/255.255.255.252 on interface {FB74DA04-E3FB-4D6B-B5CF-22B95BB25E7A} [DHCP-serv: 10.4.95.205, lease-time: 31536000]
. 2014.09.15 19:12:46 - OpenVPN > Successful ARP Flush on interface [17] {FB74DA04-E3FB-4D6B-B5CF-22B95BB25E7A}
. 2014.09.15 19:12:51 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2014.09.15 19:12:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 37.48.81.6 MASK 255.255.255.255 192.168.0.1
. 2014.09.15 19:12:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2014.09.15 19:12:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2014.09.15 19:12:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:12:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2014.09.15 19:12:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:12:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.95.205
. 2014.09.15 19:12:51 - Starting Management Interface
. 2014.09.15 19:12:51 - OpenVPN > Initialization Sequence Completed
! 2014.09.15 19:12:51 - Flushing DNS
! 2014.09.15 19:12:51 - Checking route
W 2014.09.15 19:13:01 - The operation has timed out
! 2014.09.15 19:13:01 - Disconnecting
. 2014.09.15 19:13:01 - Management - Send 'signal SIGTERM'
. 2014.09.15 19:13:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2014.09.15 19:13:01 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2014.09.15 19:13:01 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2014.09.15 19:13:01 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2014.09.15 19:13:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.95.205
. 2014.09.15 19:13:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2014.09.15 19:13:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 37.48.81.6 MASK 255.255.255.255 192.168.0.1
. 2014.09.15 19:13:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:13:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:13:06 - OpenVPN > Closing TUN/TAP interface
. 2014.09.15 19:13:06 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2014.09.15 19:13:07 - Connection terminated.
! 2014.09.15 19:13:10 - Checking authorization
! 2014.09.15 19:13:19 - Connecting to Taygeta (Netherlands, Amsterdam)
. 2014.09.15 19:13:20 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 18 2014
. 2014.09.15 19:13:20 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.09.15 19:13:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.09.15 19:13:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.09.15 19:13:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:13:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:13:20 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2014.09.15 19:13:20 - OpenVPN > UDPv4 link local: [undef]
. 2014.09.15 19:13:20 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.6:443
. 2014.09.15 19:13:20 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.81.6:443, sid=1e1a279c f1d2b5f9
. 2014.09.15 19:13:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.09.15 19:13:21 - OpenVPN > Validating certificate key usage
. 2014.09.15 19:13:21 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2014.09.15 19:13:21 - OpenVPN > VERIFY KU OK
. 2014.09.15 19:13:21 - OpenVPN > Validating certificate extended key usage
. 2014.09.15 19:13:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.09.15 19:13:21 - OpenVPN > VERIFY EKU OK
. 2014.09.15 19:13:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.09.15 19:13:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.15 19:13:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:13:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.15 19:13:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.15 19:13:27 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.09.15 19:13:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.81.6:443
. 2014.09.15 19:13:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.09.15 19:13:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.95.206 10.4.95.205'
. 2014.09.15 19:13:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.09.15 19:13:30 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.09.15 19:13:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.09.15 19:13:30 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.09.15 19:13:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.09.15 19:13:30 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.09.15 19:13:30 - OpenVPN > open_tun, tt->ipv6=0
. 2014.09.15 19:13:30 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{FB74DA04-E3FB-4D6B-B5CF-22B95BB25E7A}.tap
. 2014.09.15 19:13:30 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.09.15 19:13:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.95.206/255.255.255.252 on interface {FB74DA04-E3FB-4D6B-B5CF-22B95BB25E7A} [DHCP-serv: 10.4.95.205, lease-time: 31536000]
. 2014.09.15 19:13:30 - OpenVPN > Successful ARP Flush on interface [17] {FB74DA04-E3FB-4D6B-B5CF-22B95BB25E7A}
. 2014.09.15 19:13:35 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2014.09.15 19:13:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 37.48.81.6 MASK 255.255.255.255 192.168.0.1
. 2014.09.15 19:13:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2014.09.15 19:13:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2014.09.15 19:13:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:13:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2014.09.15 19:13:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:13:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.95.205
. 2014.09.15 19:13:35 - Starting Management Interface
. 2014.09.15 19:13:35 - OpenVPN > Initialization Sequence Completed
! 2014.09.15 19:13:35 - Flushing DNS
! 2014.09.15 19:13:35 - Checking route
W 2014.09.15 19:13:45 - The operation has timed out
! 2014.09.15 19:13:45 - Disconnecting
. 2014.09.15 19:13:45 - Management - Send 'signal SIGTERM'
. 2014.09.15 19:13:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2014.09.15 19:13:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2014.09.15 19:13:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2014.09.15 19:13:45 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2014.09.15 19:13:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.95.205
. 2014.09.15 19:13:50 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2014.09.15 19:13:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 37.48.81.6 MASK 255.255.255.255 192.168.0.1
. 2014.09.15 19:13:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:13:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.95.205
. 2014.09.15 19:13:50 - OpenVPN > Closing TUN/TAP interface
. 2014.09.15 19:13:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2014.09.15 19:13:50 - Connection terminated.
I 2014.09.15 19:13:52 - Cancel requested.
I 2014.09.15 19:13:52 - DNS of a network adapter restored to original settings (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller)
I 2014.09.15 19:13:52 - Session terminated.
! 2014.09.15 19:14:52 - Deactivation of Network Lock
The following problem:
could be caused either by a slow or failed connection. To discern the case, try to disable "Checking if the tunnel effectively works" in "AirVPN" -> "Preferences" -> "Advanced", try again a connection to a VPN server, browse to https://airvpn.org and check whether the central bottom box is green or red.
We're looking forward to hearing from you.
I did what you advised me and it still disconnects, I have attached the log, this is my desktop so my laptop on the other hand it works fine.........
I 2014.09.16 11:46:53 - AirVPN client version: 2.5, System: Windows, Architecture: x64
. 2014.09.16 11:46:53 - Reading options from C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\AirVPN.xml
. 2014.09.16 11:46:53 - Data Path: C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable
. 2014.09.16 11:46:53 - App Path: C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable
. 2014.09.16 11:46:53 - Executable Path: C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\AirVPN.exe
. 2014.09.16 11:46:53 - Command line arguments:
. 2014.09.16 11:46:54 - Operating System: Microsoft Windows NT 6.2.9200.0
I 2014.09.16 11:46:54 - OpenVPN Driver - TAP-Windows Adapter V9
I 2014.09.16 11:46:54 - OpenVPN - Version: OpenVPN 2.3.4 (C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\openvpn.exe)
I 2014.09.16 11:46:54 - SSH - Version: plink 0.63 (C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\plink.exe)
I 2014.09.16 11:46:54 - SSL - Version: stunnel 4.56 (C:\Users\Robodonster\Downloads\AirVPN\Eddie 2.5\airvpn_windows8_x64_portable\airvpn_windows8_x64_portable\stunnel.exe)
I 2014.09.16 11:46:54 - IPV6: Available
! 2014.09.16 11:46:54 - Ready
I 2014.09.16 11:47:00 - Session starting.
! 2014.09.16 11:47:00 - Checking environment
! 2014.09.16 11:47:00 - Checking authorization
! 2014.09.16 11:47:00 - Connecting to Grumium (Canada, Toronto, Ontario)
. 2014.09.16 11:47:01 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 18 2014
. 2014.09.16 11:47:01 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.09.16 11:47:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.09.16 11:47:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.09.16 11:47:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.16 11:47:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.16 11:47:01 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2014.09.16 11:47:01 - OpenVPN > UDPv4 link local: [undef]
. 2014.09.16 11:47:01 - OpenVPN > UDPv4 link remote: [AF_INET]199.19.95.187:443
. 2014.09.16 11:47:01 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.95.187:443, sid=3955db24 a320291d
. 2014.09.16 11:47:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.09.16 11:47:01 - OpenVPN > Validating certificate key usage
. 2014.09.16 11:47:01 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2014.09.16 11:47:01 - OpenVPN > VERIFY KU OK
. 2014.09.16 11:47:01 - OpenVPN > Validating certificate extended key usage
. 2014.09.16 11:47:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.09.16 11:47:01 - OpenVPN > VERIFY EKU OK
. 2014.09.16 11:47:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.09.16 11:47:07 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.16 11:47:07 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.16 11:47:07 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.09.16 11:47:07 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.09.16 11:47:07 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.09.16 11:47:07 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.95.187:443
. 2014.09.16 11:47:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.09.16 11:47:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.22.170 10.4.22.169'
. 2014.09.16 11:47:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.09.16 11:47:09 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.09.16 11:47:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.09.16 11:47:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.09.16 11:47:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.09.16 11:47:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.09.16 11:47:09 - OpenVPN > open_tun, tt->ipv6=0
. 2014.09.16 11:47:10 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{3B54C085-2090-4298-943F-BBD06A3EAA83}.tap
. 2014.09.16 11:47:10 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.09.16 11:47:10 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.22.170/255.255.255.252 on interface {3B54C085-2090-4298-943F-BBD06A3EAA83} [DHCP-serv: 10.4.22.169, lease-time: 31536000]
. 2014.09.16 11:47:10 - OpenVPN > Successful ARP Flush on interface [12] {3B54C085-2090-4298-943F-BBD06A3EAA83}
. 2014.09.16 11:47:15 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2014.09.16 11:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.19.95.187 MASK 255.255.255.255 192.168.0.1
. 2014.09.16 11:47:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2014.09.16 11:47:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2014.09.16 11:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.22.169
. 2014.09.16 11:47:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2014.09.16 11:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.22.169
. 2014.09.16 11:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.22.169
. 2014.09.16 11:47:15 - Starting Management Interface
. 2014.09.16 11:47:15 - OpenVPN > Initialization Sequence Completed
! 2014.09.16 11:47:15 - Flushing DNS
! 2014.09.16 11:47:15 - Checking DNS
W 2014.09.16 11:47:27 - No such host is known
! 2014.09.16 11:47:27 - Disconnecting
. 2014.09.16 11:47:27 - Management - Send 'signal SIGTERM'
. 2014.09.16 11:47:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2014.09.16 11:47:27 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2014.09.16 11:47:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2014.09.16 11:47:27 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2014.09.16 11:47:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.22.169
. 2014.09.16 11:47:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2014.09.16 11:47:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 199.19.95.187 MASK 255.255.255.255 192.168.0.1
. 2014.09.16 11:47:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.22.169
. 2014.09.16 11:47:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.22.169
. 2014.09.16 11:47:32 - OpenVPN > Closing TUN/TAP interface
. 2014.09.16 11:47:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2014.09.16 11:47:32 - Connection terminated.
I 2014.09.16 11:47:33 - Cancel requested.
I 2014.09.16 11:47:34 - Session terminated.
No changes by "force DNS" checked...
Do you mean that you again get "No such host is known" log line? Can you re-post the logs if in doubt?
