Not connected, Your IP: 18.224.199.201
I am running dd-wrt WTR54GS travel router flashed with dd-wrt v24 (05/24/08) vpn- 9526 the only vpn version I know made for this router, but in this flash there is no place to put the tls-auth keys, does anyone knows of a way. I have the Certificates and the RSA keys copied and installed, but no connected to the server.. Any help would be appreciated.. Thanks
A340
Thanks for the reply,  do you know if this version can load on a wRt54GS? I stress WRT as it is no the same as WTR This is a special router, that is supported by DD-WRT but there are only one or two firmware available for this unit. My current firmware does not have that field for the TLS..
A340
