Tjodbrok
Issues with Comodo Firewall
So, I recently got a new computer and I wanted to get my VPN up and running on it as soon as possible. I set everything up like it was before, I've added a picture showing my rulesets. Everything was working fine and then I needed to restart my computer for some reason. When I came back, I could connect to AirVPN, but no website would load. As soon as I deactivate Comodo, everything's fine and I can access the internet. I've got all the entry IPs correct and everything, so I don't know why it's refusing to let me access the internet.
Anyone got any ideas?
And here're some logs from Aquilae:
Fri Sep 05 01:16:03 2014 OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [iPv6] built on Aug  7 2014
Fri Sep 05 01:16:03 2014 library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
Enter Management Password:
Fri Sep 05 01:16:03 2014 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Fri Sep 05 01:16:03 2014 Need hold release from management interface, waiting...
Fri Sep 05 01:16:04 2014 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Fri Sep 05 01:16:04 2014 MANAGEMENT: CMD 'state on'
Fri Sep 05 01:16:04 2014 MANAGEMENT: CMD 'log all on'
Fri Sep 05 01:16:04 2014 MANAGEMENT: CMD 'hold off'
Fri Sep 05 01:16:04 2014 MANAGEMENT: CMD 'hold release'
Fri Sep 05 01:16:04 2014 Control Channel Authentication: tls-auth using INLINE static key file
Fri Sep 05 01:16:04 2014 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 05 01:16:04 2014 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 05 01:16:04 2014 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Sep 05 01:16:04 2014 UDPv4 link local: [undef]
Fri Sep 05 01:16:04 2014 UDPv4 link remote: [AF_INET]46.165.208.70:443
Fri Sep 05 01:16:04 2014 MANAGEMENT: >STATE:1409894164,WAIT,,,
Fri Sep 05 01:16:04 2014 MANAGEMENT: >STATE:1409894164,AUTH,,,
Fri Sep 05 01:16:04 2014 TLS: Initial packet from [AF_INET]46.165.208.70:443, sid=c85b39b7 245d5947
Fri Sep 05 01:16:05 2014 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Fri Sep 05 01:16:05 2014 Validating certificate key usage
Fri Sep 05 01:16:05 2014 ++ Certificate has key usage  00a0, expects 00a0
Fri Sep 05 01:16:05 2014 VERIFY KU OK
Fri Sep 05 01:16:05 2014 Validating certificate extended key usage
Fri Sep 05 01:16:05 2014 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri Sep 05 01:16:05 2014 VERIFY EKU OK
Fri Sep 05 01:16:05 2014 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Fri Sep 05 01:16:07 2014 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Sep 05 01:16:07 2014 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 05 01:16:07 2014 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Sep 05 01:16:07 2014 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 05 01:16:07 2014 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Fri Sep 05 01:16:07 2014 [server] Peer Connection Initiated with [AF_INET]46.165.208.70:443
Fri Sep 05 01:16:08 2014 MANAGEMENT: >STATE:1409894168,GET_CONFIG,,,
Fri Sep 05 01:16:09 2014 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri Sep 05 01:16:09 2014 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.68.46 10.4.68.45'
Fri Sep 05 01:16:09 2014 OPTIONS IMPORT: timers and/or timeouts modified
Fri Sep 05 01:16:09 2014 OPTIONS IMPORT: LZO parms modified
Fri Sep 05 01:16:09 2014 OPTIONS IMPORT: --ifconfig/up options modified
Fri Sep 05 01:16:09 2014 OPTIONS IMPORT: route options modified
Fri Sep 05 01:16:09 2014 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Fri Sep 05 01:16:09 2014 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Sep 05 01:16:09 2014 MANAGEMENT: >STATE:1409894169,ASSIGN_IP,,10.4.68.46,
Fri Sep 05 01:16:09 2014 open_tun, tt->ipv6=0
Fri Sep 05 01:16:09 2014 TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{0D1C5D6D-5A5B-4015-B07F-0A0F54BD4DE4}.tap
Fri Sep 05 01:16:09 2014 TAP-Windows Driver Version 9.21
Fri Sep 05 01:16:09 2014 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.68.46/255.255.255.252 on interface {0D1C5D6D-5A5B-4015-B07F-0A0F54BD4DE4} [DHCP-serv: 10.4.68.45, lease-time: 31536000]
Fri Sep 05 01:16:09 2014 Successful ARP Flush on interface [34] {0D1C5D6D-5A5B-4015-B07F-0A0F54BD4DE4}
Fri Sep 05 01:16:14 2014 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Fri Sep 05 01:16:14 2014 C:\Windows\system32\route.exe ADD 46.165.208.70 MASK 255.255.255.255 ***.***.*.***
Fri Sep 05 01:16:14 2014 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
Fri Sep 05 01:16:14 2014 Route addition via IPAPI succeeded [adaptive]
Fri Sep 05 01:16:14 2014 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.68.45
Fri Sep 05 01:16:14 2014 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
Fri Sep 05 01:16:14 2014 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.68.45
Fri Sep 05 01:16:14 2014 MANAGEMENT: >STATE:1409894174,ADD_ROUTES,,,
Fri Sep 05 01:16:14 2014 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.68.45
Fri Sep 05 01:16:14 2014 Initialization Sequence Completed
Fri Sep 05 01:16:14 2014 MANAGEMENT: >STATE:1409894174,CONNECTED,SUCCESS,10.4.68.46,46.165.208.70
Fri Sep 05 01:22:42 2014 SIGTERM received, sending exit notification to peer
Fri Sep 05 01:22:47 2014 C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.68.45
Fri Sep 05 01:22:47 2014 Route deletion via IPAPI succeeded [adaptive]
Fri Sep 05 01:22:47 2014 C:\Windows\system32\route.exe DELETE 46.165.208.70 MASK 255.255.255.255 ***.***.
Fri Sep 05 01:22:47 2014 C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.68.45
Fri Sep 05 01:22:47 2014 C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.68.45
Fri Sep 05 01:22:47 2014 Closing TUN/TAP interface
Fri Sep 05 01:22:47 2014 SIGTERM[soft,exit-with-notification] received, process exiting
Fri Sep 05 01:22:47 2014 MANAGEMENT: >STATE:1409894567,EXITING,exit-with-notification,,
Another thing I've noticed is that sometimes my IP address isn't covered. Like, I'll be connected to AirVPN, but IPLeak,net and DNSLeakTest.com will both show me as only connected to my home network.
