Not connected, Your IP: 216.73.216.14
SOBroin
Problems installing the GUI
Hi All
Can you help me with what is possibly a very simple problem.
I have recently downloaded the AIR VPN client for mac
https://airvpn.org/macosx/
But when I go to install I get the error message below
“AirVPN” is damaged and can’t be opened. You should move it to the Trash.
I have downloaded the file onto 2 seperate macs and get the same error.
I have rebooted and re downloaded (Same problem)
Is there something I'm missing?
Any suggestions would be great.
Thanks a Mil
SOBroin
Ok, bug detected, the archive was corrupt due a system error in the update. A fixed package for OS X has been uploaded, can you please try to re-download?
Hi All
Thanks a Mil
SOBroin
This normally happens if gatekeeper is turned on in security preferences and you try to install apps that are not MAS signed. Try to turn it off.
I'm running ox mavericks (latest version) I'll re download when I get home and post result.
Thanks a million for all your help
Sean
Actually there was a problem with privileges authorization request on OS X. We have uploaded a fixed version, can you please re-download and re-try?
