Not connected, Your IP: 216.73.216.28
Gunther
Thanks and Appreciation
I have been a Beta tester for awhile now. Mostly use your connection for IRC. I wanted to thank you for the use of your services.
If you use this in your IP tables the members should be stealth.
-I instead of -A
I use IRC too.... we're lucky enough that the IP address we sharing is not banned yet on popular IRC servers (e.g. Rizon... since they were strict and never tolerate to ban you if you do a little mistake/violation on their channels)
Anyway, thanks AirVPN for the service you give to us on beta phase. Keep up the good work.
Yeah. Thanks for the beta service I enjoyed/ All I can say now is thanks, you have the best VPN service.
