Not connected, Your IP: 216.73.216.75
illedan2
MANAGEMENT: Client disconnected error OpenVPN dd-wrt
Hi Guys,
I can successfully connect using OpenVPN and I can use the internet fine, but in the error logs I have a lot of these. I have searched the forum, google, and even dd-wrt forum but there doesn’t seem to be a definitive answer. Is this part of normal operation or something I should be concerned with?
I am using a Linksys E3000 with a popular and stable build DD-WRT v24-sp2 (12/24/10) big - build 15962
20140504 00:03:34 MANAGEMENT: Client connected from 127.0.0.1:5001
20140504 00:03:34 D MANAGEMENT: CMD 'state'
20140504 00:03:34 MANAGEMENT: Client disconnected
Thanks for any help.
Have you tried with a recent firmware of DD-WRT? The build you are using might be outdated.
Hi Guys,
As amires stated, it could be your DD-WRT build is very old. I am running Build 23838 03/29/14.
With Heartbleed and all the other privacy issues that have been updated with OpenVPN your version may not be compatable any longer.
Funny you should mention that I have been looking at later builds before reading this. I am going to try 04-18-2014-r23919/ tonight and see how I get on thanks.
Hi, I'm using DD-WRT on a Netgear NightHawk R7000 100PES and my airvpn worked perfectly all last year on UDP until I moved, but the new ISP seems to block that. (I'm living in Spain - the internet system here is still at the "bang the rocks together guys" stage). I solved that by changing to TCP and that has worked fine for 2 days. Now I am getting this "client disconnected" error. I have read the other post answers about upgrading so I have just burned V3.0 r29020M Kongac (02/02/16!) and tried with LZO No / Yes / Adaptive. It does seem to use tun1 though.
Thanks for any help
 Log OpenVPN
20160203 05:31:59 I TUN/TAP device tun1 opened
20160203 05:31:59 TUN/TAP TX queue length set to 100
20160203 05:31:59 I do_ifconfig tt->ipv6=1 tt->did_ifconfig_ipv6_setup=0
20160203 05:31:59 I /sbin/ifconfig tun1 10.5.2.223 netmask 255.255.0.0 mtu 1500 broadcast 10.5.255.255
20160203 05:31:59 I Initialization Sequence Completed
20160203 05:32:37 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20160203 05:32:37 D MANAGEMENT: CMD 'state'
20160203 05:32:37 MANAGEMENT: Client disconnected
