choq
Root and Ubuntu and Airvpn
Hi all,
on Ubuntu 12.10 with networkmanager-openvpn enabled I am able to import the generated Airvpn config. into the networkmanager after getting root. Seems logical, and makes sense. After this procedure I am able to start a vpn connection. (Other than mulvad without root rights.)
On Ubuntu 12.04 with the same networkmanager set-up, I am able ,with the new conf. generator, to import connections in the networkmanager without root rights. This is a bit confusing for me.
On Ubuntu 14.04, as we all know, networkmanager has no importbutton, which is a Ubuntu bug.
Question: do I have to be root, to configure networkmanager-openvpn and Airvpn, or not?
kind regards
choq
Ok, a bit shorter,
do I have to be root before importing Airvpn conf. into the (a) networkmanager?
kind regards
choq
