arran777
AIR VPN Protocols ?
Hi I am upgrading my internet to VDSL so I am buying a new Router which Supports VDSL, and I am thinking of using my new router to connect and create a VPN tunnel instead of using the open vpn client on my desktop.  So before I buy a new router what VPN protocol features does my new router need to have in order to connect to airvpn is it PPTP, L2TP or IPsec ?
It needs OpenVPN.
From the front page of the airvpn.org:
Uses OpenVPN to establish the connection between your computer and our servers. OpenVPN is the most reliable and secure solution for encrypted tunnels, offering a higher than military degree of security. Forget PPTP or other unsecure protocols.
I know the high end Asus routers do (think AC-68u, AC-56u as they have newer more powerful processors), and I know openvpn gets a boost if you use Merlins firmware on Asus. I also know the Netgear R7000 Nighhawk supports OpenVPN. I'm sure there are others, but you will want a premium router if you plan to use the vpn, as these high end routers max out at about 20-30 Mb/s through a vpn. Lesser routers can only do 10-15.
Or if that's not enough muscle for you, you could build a pfSense box!
