zbigniew
Gargoyle set up...problem...
hello
I have a problem with the configuration of the router with Gargoyle and openvpn ...
my config:
client
dev tun
proto tcp
remote earth.vpn.airdns.org 443
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
cipher AES-256-CBC
comp-lzo no
verb 3
ca    /etc/openvpn/grouter_client_jmsdwlyygiyk_ca.crt
cert  /etc/openvpn/grouter_client_jmsdwlyygiyk.crt
key   /etc/openvpn/grouter_client_jmsdwlyygiyk.key
and logs the connection attempt:
Apr 18 15:48:06 Gargoyle daemon.notice openvpn(custom_config)[4711]: Restart pause, 5 second(s)
Apr 18 15:48:11 Gargoyle daemon.warn openvpn(custom_config)[4711]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 18 15:48:11 Gargoyle daemon.notice openvpn(custom_config)[4711]: Re-using SSL/TLS context
Apr 18 15:48:11 Gargoyle daemon.notice openvpn(custom_config)[4711]: LZO compression initialized
Apr 18 15:48:11 Gargoyle daemon.notice openvpn(custom_config)[4711]: Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Apr 18 15:48:11 Gargoyle daemon.notice openvpn(custom_config)[4711]: Socket Buffers: R=[87380->131072] S=[16384->131072]
Apr 18 15:48:11 Gargoyle daemon.notice openvpn(custom_config)[4711]: Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
thank you for your help
