earthpeople
Trying to configure a Tor "Middle Man" relay through iptables.rules torrc
Hello and thank you in advance for any help with this. I have never ran a Tor relay before, but I would like to try to enable a "middle-man" relay through my VPN connection if it is possible.
I am trying to configure the Tor "middle-man" relay using my /etc/tor/torrc file and iptables.rules file. (I have not edited the TBB torrc)
My torrc is configured like this below:
AutomapHostsOnResolve 1
AutomapHostsSuffixes .exit,.onion
SocksPort 9050
TransPort 9040
DNSPort 9053
##Tor-middleman
Nickname ************(my secert name)
ORPort 9001
DirPort 9030
BandwidthRate 256 KB # Throttle traffic to 20KB/s
BandwidthBurst 4096 KB # But allow bursts up to 50KB/s
ExitPolicy reject *:*
and my current iptables.rules that work with AirVPN and TBB/Tor/Privoxy are:
$ iptables -L -n --line-numbers
Chain INPUT (policy DROP)
num  target     prot opt source               destination
1               icmp --  0.0.0.0/0            0.0.0.0/0            icmptype 8 recent: SET name: ping_limiter side: source mask: 255.255.255.255
2    DROP       icmp --  0.0.0.0/0            0.0.0.0/0            icmptype 8 recent: UPDATE seconds: 4 hit_count: 6 name: ping_limiter side: source mask: 255.255.255.255
3    ACCEPT     icmp --  0.0.0.0/0            0.0.0.0/0            icmptype 8
4    ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0            ctstate RELATED,ESTABLISHED
5    ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0
6    DROP       all  --  0.0.0.0/0            0.0.0.0/0            ctstate INVALID
7    UDP        udp  --  0.0.0.0/0            0.0.0.0/0            ctstate NEW
8    TCP        tcp  --  0.0.0.0/0            0.0.0.0/0            tcp flags:0x17/0x02 ctstate NEW
9    REJECT     udp  --  0.0.0.0/0            0.0.0.0/0            reject-with icmp-port-unreachable
10   REJECT     tcp  --  0.0.0.0/0            0.0.0.0/0            reject-with tcp-reset
11   REJECT     all  --  0.0.0.0/0            0.0.0.0/0            reject-with icmp-proto-unreachable
Chain FORWARD (policy DROP)
Chain OUTPUT (policy ACCEPT)
Chain TCP (1 references)
Chain UDP (1 references)
$ iptables -t nat -L -n --line-numbers
Chain PREROUTING (policy ACCEPT)
Chain INPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
If there is an easy way to do this then please let me know what I should do with ports-forward, iptables.rules, and torrc.
thanks.
EDITED: I decided to edit this cause I added too much confusing info.
So to keep things simple, I don't know if I need ports forwarded or if I just need some new iptables rules to make things work. (or both)
Currently my Tor Browser Bundle (TBB) works on port 9150 and 9151 over my VPN connection and so does my Tor/Privoxy connection using Socks4a for port 9050 and 8118. When running both tor instances I have 6 EntryGuards to start. When I configure the "middle-man" relay in my linux /etc/tor/torrc file I get about 20-80 more ESTABLISHED connection with the original 6 ESTABLISHED EntryGuards. But after a few minutes I only have the original 6 EntryGuards as ESTABLISHED connections when using the netstat command.
