kbmaster 0 Posted ... Hey Everybody Im a new member. today i tried to follow this guide. https://airvpn.org/linux/ I do use the network-manager. No matter what i do. I cannot get a zip file with the certs and keys. All i get is a opvn file with the keys and certs in it, So i have to extract them and insert them into new files. This is not mentioned in the above link. By the time you read this i will have figured out what keys goes where. Since i need a vpn asap. But i hope you can fix either the generator to always include the needed files. Or change the guide so the users know what to do. KBmaster Quote Share this post Link to post
Staff 10502 Posted ... Hello, the Configuration Generator works fine. In the instructions you can read: Select "Advanced Options"Tick "Separate certs/keys from .ovpn files"Kind regards Quote Share this post Link to post
kbmaster 0 Posted ... Im talking about the "Using AirVPN with Ubuntu NetworkManager". Which does not contain the lines you quote. (you can check) thx for the reply. Quote Share this post Link to post
Staff 10502 Posted ... Hello, yes, actually it is assumed that the instructions for Linux are read entirely. We're sorry if it has caused troubles. Kind regards Quote Share this post Link to post
