amc
Using AirVPN behind a firewall
If you successfully used AirVPN behind a firewall that blocks all traffic except for HTTP(port 80) and SSL(port: 443) and tried other VPN services before and failed please share your experience.
Thanks,
Rami
I have such experience. Firewall at my work detects normal OpenVPN, so I cannot use it alone. But when I'm using stunnel + OpenVPN all works like charm. The key point here is SSL tunnel on port 443. Before AirVPN I tried using IBVPN with stunnel, but they give stunnel configured on port other than 443 and it doesn't work in my office network.
