Not connected, Your IP: 216.73.216.104
First of all I want to emphasize that I'm no computer expert.
I wanted to use JonDo together with AirVPN. So I generated a new config file with the only difference that I added a proxy with 127.0.0.1 as host and 4001 as port. I tried both http and socks.
By the way, I got a free trial for JonDo Premium. So there should be no restriction at that point.
Any ideas?
I just tested the same with TOR, following the guidelines from airvpn.org... but it doesn't work either :/
