seaturtlekona
Where is the Air Tray Icon?
tray icons are usually on the taskbar (the same bar where you can see the "Start" or Windows logo button). The Air client tray icon is a white cloud on a gray (or blue, if connected) sky. If the Air client tray icon is not there, expand the tray icons section by clicking the arrow symbol. If it's still not there, then the Air client is probably not running.
