jameshealey94 0 Posted ... Hello, I normally connect to your servers using OpenVPN because I use the DNS fix found here:http://dnsleaktest.com/how-to-fix-a-dns-leak.html As far as I'm aware the AirVPN client does not have such a fix. When I'm at my house I use my wifi to connect, but now I am at school I use an ethernet connection. For some strange reason, OpenVPN fails to connect over my ethernet connection, but works fine over the school's wifi. Attached is a picture of the log file and the error given. The three errors I see that stand out are: No route to host, TLS key negotiation failed and TLS handshake failed. I made new configuration files, reinstalled dnsfix and tried again, no luck. It works fine over wifi, but for some reason ethernet isn't connecting. Appreciate the help. Thanks ! Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... Is ethernet working at home? Try deactivating the wifi interface and connect through ethernet again. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
