starshine
Can I use Air VPN as web proxy, torrent proxy separately?
I currently have Torguard and BTgard but your service seems nicer.
I like maximum flexibility. If I sign up with Air VPN, could I use one use the individual servers as web proxy servers and configure the torrent client using Socks5 ?
If so, is it also possible to then use VPN at the same time...
Guest Chaf
This isn' possible as the protocol supported by Air is Openvpn.
You could do what you want if you had a server (VPS or home built dedicated computer) with an Openvpn client running and then configuring yourself a proxy on it.
Many tutorials online talk about this but will be hard work and if not done correctly, you may break your anonymity by misconfiguring it all...
