bobdobbs
Excellent !
Simple to set up on Windows, OSX and Linux.
Just works.
Excellent speeds inlcuding P2P and excellent support of protocols.
NO effect on speed, forget I am connected most of the time.
Does what it says on the tin, simples.
Used many services before, nothing compares to AirVPN.
Been using for a little over a week, waited a week to review.
*Pros
Everything
*Cons
Could do with a native Linux client, not because setting it up in Linux is hard, it is just that it would be easier to manage the connect/disconnect of OpenVPN which can be a pain.
But I wouldnt really consider that a con, but had to come up with something.
Thanks AirVPN
Completely agree with you. It's so easy to use, and it works perfectly!
Let's make it a slogan. AirVPN - as easy as changing the font color!
Or even better: AirVPN - change your identity online as easy as you change the font color.
Edited ... by giganerd
As a relatively new subscriber, I have also been very pleased with AirVPN.  I subscribed primarily to insulate my Windows 7 machine's connection at home and (especially) at work, and it's been a blessing for that.  The latency for P2P telephony applications isn't always great, but that's a small price to pay (and easily remedied by turning off the network lock feature temporarily).  After the service itself, I find AirVPN's policies and stances on privacy, net neutrality, and other issues to be very agreeable with my own.  They are a sharp, enlightened group of people, and I am happy to have discovered them before spending much time & money mucking around with lesser providers.
